Car's idle dips below 500rpm when A/C is on
Old Jun 4, 2007 | 05:17 PM
Nmax92's Avatar
`sup guys. I have a problem. when I turn on my A/C the idle on the car dips below 500 and fluctuates +/- 200rpm, plus the car is very sluggish when moving off. When the A/C is off, its a bit better, but not completely normal.
Also when I start the car, it revs up to 2K rpm then drops the to 1K then to about 250rpm sputters and dies. It will start right up and have trouble staying above 700rpm, i would have to race the engine.
I'm guessing its my MAF or my belts needs adjusting, I haven't check it out yet. Any ideas guys?
Old Jun 4, 2007 | 05:42 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the maf to me...
Unplug the maf harness,then start it up,if the funky idle problem goes away,bingo..
Note:The engine will not rev over approx. 2500rpm while the maf is unplugged,and your check engine light will come on while the maf is unplugged.
Old Jun 4, 2007 | 05:43 PM
mofoaka's Avatar
intake air control valve may need some cleaning??
Old Jun 4, 2007 | 05:57 PM
Nmax92's Avatar
mygreenmax94, if your method works should I spray the MAFwith electrical cleaner
Old Jun 4, 2007 | 06:03 PM
Greeny's Avatar
¯\(°_o)/¯
It's worth a shot,i tried it with mine,but it was a no go..
Old Jun 4, 2007 | 06:23 PM
Alex_V
CRC makes a MAF cleaner, its only a few bucks. I used it on mine a while back and it ran a little smoother.
~Alex
Old Jun 4, 2007 | 06:54 PM
internetautomar's Avatar
mod or sell?
I'd blame the IAC first.
or possibly bad injectors
not enough detail to make a close diagnosis IMO
Old Jun 4, 2007 | 08:16 PM
92 Max's Avatar
There's also an idle up control for the A/C that may not be increasing the idle when the A/C is turned on. This would cause the engine to drop too low at idle. The other things may be contributing.
Old Jun 4, 2007 | 09:35 PM
Nmax92's Avatar
92 Max, do you where is the idle control for the A/C?
Old Jun 5, 2007 | 04:10 AM
Greeny's Avatar
¯\(°_o)/¯
The FICD [fast idle control device] selonoid is a integrated part of the idle control valve..
This part is located under the throttle body..
BTW,did you check the maf yet?
Old Jun 5, 2007 | 06:21 AM
Nmax92's Avatar
no, not yet. I'm going to check the maf today. I'll post later with the results.
Old Jun 5, 2007 | 07:03 AM
Nmax92's Avatar
sorry fellas, I didn't mention this is for a gxe. the se on my profile is my first baby.
Mygreenmax94, I checked the MAF. on start up the car was running quiet and smooth(with the MAF unplugged) like it came fresh from the dealer.
When I plugged it in thats when it started sputtering. check this out, with the MAF unplugged I turned the A/C on and the car just died. IS that stilll a maf problem?
I adjusted the idle to factor specs, still the same problem.
Old Jun 5, 2007 | 08:12 AM
Greeny's Avatar
¯\(°_o)/¯
Hmmm...
Here are the results of my tests on my two maximas..SE/w VE engine/GXE/w VG eingine
Both with good mafs/Iacv's
SE..
1. Unplugged maf runs as normal/stumbles momentarily when maf is plugged back in wiith engine running,then recovers..
2. Still runs fine with maf unplugged/w AC on..
GXE...
1. Runs as normal with maf unplugged..Stumbles but recovers when maf is plugged back in/w engine running..
2. Dies when AC is turned on/w maf unplugged...
According to the fsm,the VE engine iacv/ficd unit allows for more air when the AC system is turned on..
But is says nothing about the VG engine iacv/acc unit allowing for more air intake from the iacv/acc unit when the AC system is activated..
Unless someone with more knowledge of the vg iacv system chimes in,i'm still calling the maf as your problem..
Old Jun 5, 2007 | 09:59 AM
mod or sell?
start with a used MAF that you know is good, since it clearly has a problem. It mau not be your only problem though.
Old Jun 5, 2007 | 12:37 PM
Nmax92's Avatar
I defintely think its the maf also. I cleaned the terminals and the filament on the maf, I clean the iacv, tightened the alternator belt(thought the system isn't charging enough...preventive maintenance), and adjusted the idle again.
so far its running ok. The next test is to start it in the morning if I get the same result I'm going to get a new maf and move on from there.
Old Jun 6, 2007 | 03:52 AM
Nmax92's Avatar
I had the smae stalling on startup this morning. Its confirmed it is the maf.
Old Jun 22, 2007 | 06:51 PM
TxMaxima93's Avatar
MAF Sensor
How in the sam hill do you just unplug the thing I just want to check it.
Old Jun 22, 2007 | 07:47 PM
Greeny's Avatar
¯\(°_o)/¯
Use a small pick or other suitable tool to push the metal clip open while gently pulling back on the connector
Old Jun 22, 2007 | 07:52 PM
'93maximaGXE's Avatar
haha, i thought you had to take the screws out to take it off.
Old Jun 22, 2007 | 08:03 PM
TxMaxima93's Avatar
MAF Sensor
Naw I wasnt going to take the screws off I learned a lesson by doing that on something i couldnt put back
Old Jun 22, 2007 | 10:19 PM
x91max
if u disconnect the maf and the car dont start no more until you plug it back in whats that mean?
Old Jun 22, 2007 | 10:27 PM
TxMaxima93's Avatar
MAF Sensor
Well for me I am hoping its the MAF or the knock sensor this loss of power is baffling. When I went to get it tuned the guy told me I need to spend $1200 on a compression test and it would take 3 days. I was like hmmmm let me get back to you.
Old Jun 22, 2007 | 10:31 PM
x91max
you can do a compression test urself given 3 hours of work. mine has its good days and its bad. sometimes itll have all the power in the world and others it will barely be able to start off.
Old Jun 23, 2007 | 09:38 AM
cachejob's Avatar
time for a new mechanic...
Old Jun 23, 2007 | 09:58 AM
TxMaxima93's Avatar
MAF Sensor
I disconnected the MAF and the car just dies. I try to restart it and i have to rev it to keep it running.
Old Jun 23, 2007 | 07:44 PM
mod or sell?
check for a vacuum leak.
Old Jun 25, 2007 | 07:35 AM
TxMaxima93's Avatar
MAF Sensor
Amazing I just replaced my MAF this morning I havent reset the ECU yet but I can already see the difference my car now has the power back. That's crazy that one sensor just makes the car run like crap when it goes bad. Thanks for all the help. Now I'm off to fix the power locks
Old Jun 27, 2007 | 05:16 PM
TxMaxima93's Avatar
Is the dealership the only place you can get the ECU reprogrammed
Old Jun 27, 2007 | 05:40 PM
Greeny's Avatar
¯\(°_o)/¯
Reprogrammed?the dealer can't anything but check/clear codes from your ecu,which you can do yourself for free..
JWT can remap your ecu for about a gazillion bucks.
Old Jun 27, 2007 | 06:21 PM
traxtar944's Avatar
Would be lost w/out the org
My car dies when the MAF is unplugged, too. That's because of a vacuum leak? What is the procedure for diagnosing where the leak is?
Hmm...I found that the vacuum tube going from the intake manifold to the water **** solenoid was disconnected. This is for the AC unit, but could it be causing the engine to stop when removing the MAF? Because it still stops running when unplugged.
Old Jun 27, 2007 | 06:28 PM
TxMaxima93's Avatar
Service Request for Sterling McCall Nissan in Houston
If its just a reprogram with no other work performed $105.00
Thanks,
Bruce
Just wanted to make sure that this is about avg as far as the price goes.
Old Jun 27, 2007 | 06:31 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks,
Bruce
Reprograms via consult tool are for later OBDII ecu's,not our ecu(OBDI)
Old Jun 28, 2007 | 08:28 PM
Tquick's Avatar
Any vacuum hose that is disconnected is going to cause a vacuum leak, regardless of what it is supposed to be connected to, and any vacuum leak is going to cause the engine to run poorly.
Old Jun 29, 2007 | 04:50 AM
DaWifey's90's Avatar
what can my max do for me
i have the exact same issue on my 90 SE VG. turn the AC on an it feels like i'm towing a rig, turn off the AC and almost immediately it feels like i picked up 4 more cylinders.
i'll have to test the MAF
here's my ?
is it possible that the added load of engaging the compressor will exacerbate an existing condition that otherwise may not be severe enough to be detected?
Old Jun 29, 2007 | 07:51 AM
mod or sell?
Originally Posted by DaWifey's90
here's my ?
short answer: Yes.
Old Jun 30, 2007 | 12:55 PM
nimmy's Avatar
I'm having the same prob, went and took off the plug on my maf... it ran better at about 500rpm with no loss in rpms.. when i tryed to give it a little gas it went up then down and caught itself at 500rpm (cold engine). I plugged it back in and it completely went bonkers on me and started idling rough/trying to pull me while i was had my foot on the break in drive every couple seconds....
So I guess thats my maf, autozone cost.. 205.00 dollars, cleaning price, a few dollars? Are there any instructions on how to clean? I have a 95 btw, just found this post through search.
Old Jun 30, 2007 | 03:17 PM
Greeny's Avatar
¯\(°_o)/¯
You could try to clean it,worth a shot..
Cleaning instructions-->http://videos.streetfire.net/video/4...6f015c3dac.htm
If cleaning don't work,try a used unit from the classifieds section here on the org..
Classifieds link-->http://forums.maxima.org/forumdisplay.php?f=61
Old Jun 30, 2007 | 04:12 PM
Joe Rockhead's Avatar
Hi Guys.
My 94 GXE has just started to do the same "stalling when cold","rough idle when a/c is on". I cleaned iacv (was pretty clean inside), but I think that the step motor attached to the front of the iacv may be bad! Any test for that? Any Ideas?
Thanks,
Joe
Old Jul 4, 2007 | 01:41 AM
holy cow people!!!
i pulled my MAF sensor and simply blew into it and reinstalled it. I CAN'T BELIEVE THE DIFFERENCE!!
so i picked up the MAF sensor cleaner and even more results!!!
i switched back to the stock cleaner (from an oiled-gauze type) and i almost have my chirp-in-2nd back!!
i know it has more problems but i can't believe the difference cleaning out the MAF made.
thanks yet again guys!!!
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
scarletsosa
Aug 17, 2015 09:09 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
doobadoo
Aug 15, 2015 06:43 PM
