Questions about CAI
would it be possible to do a cai and hai? you could use something like a y-pipe and send the cai tube in front of the battery and make the hai go back the way you all are taking the cai tube or something similar?
Also... what are these "Would it be possible" questions? Of course it is possible, if you can move things, find the right piping, and route things in the space alloted... than go for it. But if you're doing it for performance than I suggest you pick one or the other.
Originally Posted by MyGreenMax94
I wouldn't put the filter that low,also cutting out the plastic would expose the filter to direct rain water when driving...
If you are going to do this,just put the filter under the headlight,it is the best place for it...
if you do this you can put that thing over the filter, (i forgot what its called) but it keeps water out, its kinda like a bag but allows continuous air flow to the filter.
I'm not really sure what you are referring to exactly..
Ahh..The filter diaper..
Still,the best place for the filter is under the driver side headlight...it's also the easiest area to modify,minimal cutting...
i took my CAI off on my VE
thought it was time to clean it (my parking lot at work is a desert)
took it out and it was all rusty and crap...
took it off and put on the adapter to have a short ram intake, louder IMO
and also little more power?...
ever try and suck through a 6' straw?
or a "Golf ball through a garden hose!" <--- lol
Originally Posted by heresmymind
Gas millage +1-2 miles a galon for me. although my orignal filter was dirty on my HAI and i put a K+N on the CAI. It requires very little cutting of the piping. and you should buy a piece of 2.75" flex hose. then you remove our fuse box on the side of the battery to put the pipe under it. Here it is with out the flex hose / k+n filter.
Originally Posted by ColombianMax
N00b question, how fun is it to change your air/cone filter? and how long does it take?
Just undo the clamp in the engine bay,then bring the filter/90* elbow out the bottom..Replace/clean/reinstall...Drive happy..
Man this thread really makes me wanna order a damn Accord CAI, I dont have a dremel though
I know Maxshima94 didnt cut anything, are there any pros/cons as to cutting or not?
Originally Posted by Jeff92se
I designed mine so you pull it from the top. Not sure what size pipe that accord stuff is but I thought it wasn't a full 3"? this is a pic of 3" tubing all around
Accord Is 2.75" Inside Diameter.
IMHO that's too small. Cattman's CAI filter (shown in my pics as I used the same one that kit uses) accepts a 3" pipe. So I used 3" from the filter all the way to the maf.(pic) If you look at the accord versions, you can see the pipe going up in size when it gets to the maf.
yes. 2.75" i cut away in that first pic. I'll have to take a 2nd pic of the new set up. i used a 2.75" - 3" converter on the end of an 90 degree elbow So i could put on the 3" K+N filter. I take my headlight off. then bring the filter up from underneath the bumper and put it on. I've taken my headlights off plenty of times so 1 more time doesnt bother me:-p
Unclejunebug
Apr 2, 2016 05:42 AM
