What are these wires from???
Old Oct 19, 2000 | 03:17 PM
FitzMax's Avatar
I was just outside in my car and I was taking apart the front panel of my dash(where the radio sits). Under the shift boot and shift plate(5-spd) I noticed that there were a series of wires running into two connectors under there, but they were disconnected. I am not sure if this is from the airbag recall that our cars had or if it is something else. Please let me know if you have any ideas. Thanks.
Old Oct 19, 2000 | 03:59 PM
«§»Craig B«§»'s Avatar
it is probably for overdrive unit in automatics or it would go to the power/comfort switch in an automatic
Old Oct 19, 2000 | 04:04 PM
Matt93SE's Avatar
STFU n00b!
Also don't forget about the transmission lock thingy.. there's a relay under the dash that unlocks the shifter when you step on the brake..
all that mess is inside the shifter, so that'll require wires.
ANd there's also the o/d switch.
the power/comfort switch stops at the bottom of the console, just under the ashtray.
Old Oct 19, 2000 | 04:10 PM
FitzMax's Avatar
The two ends of the connectors are there but they are disconnected. I don't think it is the o/d (I have a 5-speed) but I am just curious as to what they might be and if I should hook them up or let them be.
Old Oct 19, 2000 | 04:55 PM
I was just saying that it's probably for the overdrive swithc in the shifter and like matt said the shift lock; I know you have a 5spd so you dont' have a need for these things, but some things nissan just has in there that you don't need and since you have a 5spd, they aren't hooked to anything
Old Oct 19, 2000 | 05:03 PM
FitzMax's Avatar
Oh I see. Your probably right about the o/d. It doesn't look like it has ever been connected because one end has that factory style foam wrapped around it. I was just wondering if anyone else had seen something like this in their cars. Thanks guys.
Old Oct 19, 2000 | 05:15 PM
Jeff92se's Avatar
I'm needing a caw
Looks like a neat way to hook up a kill->
switch.
Old Oct 19, 2000 | 08:39 PM
shawn's Avatar
i found that same wire harness on my max. this may be different but i called nissan (i'm in canada) and they told me that it was for a "shift light"
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
