Headlight Relay
Old Jun 22, 2007 | 10:38 AM
maxima_man1992's Avatar
Headlight Relay
I recently bought a 1992 Maxima SE and the right front headlight is out, thought it would be a simple fix to you know replace the headlight. Turns out that the wireing on the headlight is bad or sumthing. The headlight wont work when they are on but when you turn on the brights it does work. Its like its not getting enough power. I just wanted to know where the relays were for the headlights. What do you guys think it could be?
Old Jun 22, 2007 | 10:49 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=434582
Old Jun 22, 2007 | 10:55 AM
so i need a new switch or is it just dirty?
Old Jun 22, 2007 | 10:58 AM
Greeny's Avatar
¯\(°_o)/¯
Try cleaning the contacts like i shown how to do in the thread link,if that doesn't work then yes,a new switch would be in order..
Old Jun 22, 2007 | 11:14 AM
mikekantor's Avatar
Or it could be simpler: the bulb has 2 filaments, possibly only one is out.
Swap bulbs between your headlights, see what happens. Its good to test and narrow down possible issues before replacing everything in sight.
Old Jun 22, 2007 | 11:19 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 22, 2007 | 11:40 AM
sweet they work and it only took like 10-15 mins to do it all, wow thanks for your help guys
Old Jun 22, 2007 | 12:05 PM
mikekantor's Avatar
replace the headlight != replace the bulb
anyway, glad it works now.
Old Jun 27, 2007 | 01:23 PM
Spacend's Avatar
My fog lights don't work. Checked fuse on driver side, relay near battery, bulbs, nothing> Suggestions?? Also my reverse lights don't work too. Nissan said part was like 60 bucks and I would have to drain the trainy, so I'm thinking I could just wire the reverse lights to a switch in the dash. Anybody done this before??
Old Jun 28, 2007 | 08:31 PM
Tquick's Avatar
That would be a nasty rig job. You could do it, but it's half rear ended, and not the way to fix your car, and at least in NY, it'll get you a ticket if you are caught with your reverse lights rigged to a manual switch. Buy the part, and fix it properly. As for the fog lights, pull out a bulb, and verify that you are, or are not getting power at the light. If there is power at the light socket, check the ground. If there is no power at the light socket, then start working your way back toward the battery, checking for power until you find where the problem is.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
