Steering Bushing
Steering Bushing
Yesterday I went to get an alignment at a shop. The guy tells me that he cannot do the alignment because the rack and pinion bushing is worn. If he does it the alignment wouldn't stay the car would swerve to one side.
I told him to do the alignment anyway, was I wrong to have him do it? Its seems that auto stores don't carry the bushing. The dealer has it, but it has to be ordered.
Is the bushing for a 1995 or newer fit the 1992? Is it a stiffer bushing? How much of a difference does a worn bushing have on the steering of a car?
My opinion any bushing that deals with steering ball joints control arm bushing tie rods etc. will have an effect on the car. And if not changed soon will could cause more problems.Like the domino effect. Remember one piece is connected to another and another.
Autozone/advanced auto/Napa all can order the rack bushings for around $10..
Also,the 1995 4th gen bushings will not fit,the part #s are completely different..
Typically,when the rack bushings are worn out,the steering wheel will sometimes not return back to center after making a turn,also you may feel some front end play on rough/uneven road surfaces...
Internetautomar - I'm gonna order the bushings from you. Do you carry the adjusting bolt for the alternator, I need one. Thanks for the feedback fellas
Originally Posted by CyMax
I'm going to get my rack ( giggle RACK giggle
) and upper balljoints replaced soon, so I should hold out on tires and an alignment right??
) and upper balljoints replaced soon, so I should hold out on tires and an alignment right??Yes,wait until all front/rear worn out suspension parts are replaced until you get an alignment..
Originally Posted by MyGreenMax94
Upper balljoints? maximas only have one lower balljoint per side..
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
