passenger side window regulator/rail
Old Jul 3, 2007 | 01:30 PM
Sevorg1's Avatar
so when rolling the window up the other day pop goes the weezle. pos. now the window goes down, and only up by hand. take off door panel and the plastic peice that sides up and down the rail has apparantly broke. plastic peices in bottom of door. sob. how much should I pay for that assembly. I got some quotes in town one for $100 the other for $45
anyone got one they are willing to give up ?
Old Jul 3, 2007 | 01:33 PM
Greeny's Avatar
¯\(°_o)/¯
Ebay,about $40.
Old Jul 3, 2007 | 01:36 PM
Greeny's Avatar
¯\(°_o)/¯
http://cgi.ebay.com/ebaymotors/89-94...spagenameZWDVW
Old Jul 3, 2007 | 05:01 PM
internetautomar's Avatar
mod or sell?
http://www.internetautosupply.com/ca...8869d0&x=0&y=0
Old Jul 6, 2007 | 02:06 PM
maxima2k2's Avatar
I have the same problem, I think the rear drivers window regulator is broken because it will not roll back up using the switch and it goes down by itself. After pulling the window up by hand and using the switch to roll it back down a clicking noise can be heard, which probably means the motor is still working. Typically, how long are these window regulators suppose to last because the drivers and passenger's front had to be replaced now now this one . Anyone know where I can get one?
Old Jul 6, 2007 | 02:14 PM
mod or sell?
they last about 10 yrs, depending on usage.
the link in the post above yours shows a place you can get them at.
Old Jul 6, 2007 | 03:03 PM
92 Max's Avatar
Yeah, the plastic pieces in the regulator have fallen apart. I just replaced my front one. Relatively easy job. Here's a great writeup on the job.
http://www.4dsc.com/articles/interior/index.shtml
Old Jul 6, 2007 | 03:18 PM
Cliff Clavin's Avatar
Way out West
I think most people have replaced at least one window regulator. I have done a few.
Simple, yet annoying problem. Please replace this yourself. The dealership charges waaay too much for both the part and the labor and it is very simple to replace. IIRC, you just need a screwdriver and a 10mm socket.
Just buy a new one (not used one from the junkyard) and be done with it.
Old Jul 6, 2007 | 04:09 PM
mooze's Avatar
i just did all four. can be difficult only if you cant get window down. but not your case so should b about 10 min job
Old Jul 6, 2007 | 04:35 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i replaced mine ($75 from a junkyard..) last week. My girlfriend rode in the car prior to me finishing the job, so all the bits and pieces that have to be removed to remove the weather sheet were still off, thus the door was opened with with just that metal rod, and she bent it, and it messed up my door lock. the door wouldn't open... OH GOD. But after i played around with it i saw why (the door lock timer thought the handle was being pulled when it wasn't and thus held the lock shut) so i bent it back and now it works fine.
honestly the hardest part of the job is hooking the little plastic clip on the upper cable back into the little hole you are supposed to pop it into.
Old Jul 6, 2007 | 04:53 PM
Greeny's Avatar
¯\(°_o)/¯
$75!!!
Holy crap dude,they are only about $50 new..
Old Jul 6, 2007 | 05:08 PM
mod or sell?
<snip>
um the cable is part of the regulator, you shouldn't have had to touch it
Old Jul 6, 2007 | 09:21 PM
Originally Posted by MyGreenMax94
$75!!!
my dealer wanted $100
i'm talking about a tiny tiny clip that holts the cable snugly against the interior sheetmetal of the door. it's the one you have to push through to remove the regulator. http://s164.photobucket.com/albums/u...t=IMG_2428.jpg
Old Jul 7, 2007 | 08:27 PM
mod or sell?
never noticed that clip on the 7 or so that i've done.
Old Jul 7, 2007 | 09:59 PM
Tquick's Avatar
I just replaced a regulator in my car not very long ago. There was no clip, and I got mine brand new from Auto Zone for around $70, so $75 from a junkyard was a rip off.
Old Jul 8, 2007 | 07:56 AM
kycyk's Avatar
Warning for ya.. I tried eBay (yeah yeah I know).
IE one from this seller..
http://cgi.ebay.com/ebaymotors/89-90...33573466QQrdZ1
Bought front right and left. Both are like half an inch too tall or something cuz they block the window from rolling up all the way. It mounts on OK, but .. auugh! Anyways, $40 down the drain as this seller had no return policy. Want to try the ones I have?
Old Jul 8, 2007 | 10:44 AM
Quickywd01's Avatar
That's where I got my replacement for my front right and it didn't fit 100%. The window slides slower and is not as sturdy, it moves left and right.
Old Jul 9, 2007 | 06:30 PM
Roymg's Avatar
Ive replaced my two fronts (94 max) about 5 yrs ago by the dealer. ($250 bucks each) . Now waitng for the backs to go out. No one uses the back seats so I keep them locked out of service. No matter though when they go out the window will come down by itself. This was a bad design because from what I undestand the plastic part that breaks was due to sun heat. It's been improved upon on later models.
Old Jul 9, 2007 | 08:23 PM
Tquick's Avatar
Yes, there are a number of plastic pieces in the system, and on the regulator that I replace, every one of the plastic bits was broken.
Old Jul 10, 2007 | 08:17 PM
Sevorg1's Avatar
got the one from zbra motors off ebay. works great. the down stop is alittle higher so when the window is rolled all the way down the window peeks out of the seal alittle bit but still better than the window not working at all and falling down when I got on the highway
Old Jul 10, 2007 | 08:38 PM
mooze's Avatar
got one from carpartswholesale on ebay. window doesnt go all the way up
Old Jul 11, 2007 | 08:52 AM
mod or sell?
never had a complaint out of the ones I sell.
The Wizard
24
Oct 1, 2015 08:47 PM
Bonka
Sep 14, 2015 11:18 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
