Splitting the manual transmission
Old Jul 3, 2007 | 05:26 PM
jruss1601's Avatar
I'm splitting the manual transmission cause i was told i could fix a bearing problem myself.
First problem i ran into is this. transmission is split about 3 or 4 inches and its stuck. Anyone know why?
Also, if anyone could give me any tips on doing this bearing change i'd appreciate it. thanks
Old Jul 3, 2007 | 05:29 PM
Greeny's Avatar
¯\(°_o)/¯
If you do not have the factory service manual,absolutely do not attempt to fix the bearing...
All the instructions for splitting the case is in there...
Old Jul 4, 2007 | 05:20 AM
cheatham's Avatar
I need a brake.
I did this recently. There are MANY tips (procedures) that must be followed in order to complete the rebuild. Nothing too difficult, but there is a step by step process you must follow.
DO NOT, Proceed without the FSM, you can find it in the stickies.
I used CourtesyParts website to find the check plug and check ***** that I lost in the grass due to not following the instructions to a T (and disassembling on a bench set up in the yard )
Again, D/L the FSM and work in an area where you can chase multiple small ***** . Many of these small parts are back ordered and may take a week to come in if you lose them.
Old Jul 4, 2007 | 06:52 AM
Hectic's Avatar
I just meant, I think you're capable of it considering you say you're planning on swapping engines, and trannies. Course don't try to work on your tranny unless YOU think you're capable of it. That means, read the FSM and make a decision. There are many small parts to lose or lose track of. So study the diagram and know where it all goes.
As far as why it's not cracking open, make sure you've removed all of the screws the FSM tells you to remove. A couple of them on the side have a ball and spring inside, so get those out before taking the casing off. There's also another one on the side that holds the reverse lever in place and needs to be removed for it all to separate. Take a pry bar and pry apart at the corners (there are places molded into the case for this) after its partially separated, you pull straight up on the case.
You need the FSM. Like Gmax said, it has all the info you need in there.
Old Jul 4, 2007 | 07:36 AM
mtcookson's Avatar
I did mine without the FSM... and don't recommend it. Get the FSM. Search phat g20 on Google.
Old Jul 4, 2007 | 08:45 AM
JamesNH's Avatar
try rotating the cover back and forth then pull up at the same time. Also did you remove the bolt that hold the reverse shaft in?
Old Jul 6, 2007 | 10:40 AM
jruss1601's Avatar
I just got the FSM. Let me read it and try it out.
Old Jul 6, 2007 | 01:05 PM
x91max
ive done this about 3 times on 3 diff manuals. i have an fsm on a disk i could send you. it shouldnt be to hard theres really only 6 steps. just keep an eye on what size the ***** are they go in diff places and the fsm doesnt say where. O and when you seal it back up make SURE you seal it well. otherwise youll be dropping your tranmission again cause of a leak.
Any questions feel free to ask. i have pictures of doing and pretty much know it by memory now.
Old Jul 6, 2007 | 02:00 PM
Greeny's Avatar
¯\(°_o)/¯
I would love to see some pictures of this jpex 6 speed setup you claim to have..
Here's a refresher just incase you forget which lie this was..
just pistons. motor can take it. stock transmission blew right awy tho. now i have a custom straight cut jpex 6 speed.
Old Jul 6, 2007 | 02:06 PM
internetautomar's Avatar
mod or sell?
he got an old school 3 on the tree with a gearvendors over/underdrive unit on it
Old Jul 7, 2007 | 03:04 PM
x91max
i actually made a post with pictures of it. if you cant find it. screw off. other than that quit posting stuff that doesnt belong in peoples posts. its rude
Old Jul 7, 2007 | 03:13 PM
Hectic's Avatar
oh yeah this guy..
Old Jul 7, 2007 | 03:41 PM
Greeny's Avatar
¯\(°_o)/¯
The worst thing you can do in this forum is lie,and you sir are not very good at it..
I have researched every thread /post you have ever made in here.(donating members/moderators have this feature)
None of them have these so called pics..As a matter of fact,you have never posted any pics...of anything...ever..Except of course the sig pic of another org members turbo setup..
So with all that said,have fun with your bs 27 psi turbo six speed dream car,as your posting abilities will be somewhat hindered from this point on..
Old Jul 7, 2007 | 03:42 PM
Pearl93VE's Avatar
I can has?
Oh god. Do you have a CTS-V too!?
Old Jul 7, 2007 | 05:07 PM
505max94se's Avatar
If you want to meet up sometime, I can take some pics for you... LMAO
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
sliptap
Sep 30, 2015 05:57 AM
