auto tranny shift lock thingy broken
Old Jul 11, 2007 | 08:27 PM
Sevorg1's Avatar
so the same day I replace the front passenger window regulator, the thing that unlocks the shifter lever fail to unlock it when I step on the brakes. Now I have to take the car out of park with two hands (one is used to push down the shifter lock button, and the other to press the button on side of shifter to take out of park.)
which fuse operates this locking device? anyone else have this problem? where is the soleniod that controls this (obviously under the consol somewhere)
91 max 207,000mi and counting
thanks in advance
Old Jul 12, 2007 | 07:31 AM
internetautomar's Avatar
mod or sell?
thanks in advance
http://forums.maxima.org/showthread....+lock+solenoid
Old Jul 16, 2007 | 10:08 AM
max_freak's Avatar
I have a maybe semi-related problem. I have a 93 Maxima GXE with automatic transmission. When I shift into "Drive" from "Neutral", it doesn't 'click' in at all--it stays in N. I have to push it a little past the "D" marker and then the transmission shifts into drive. This isn't a problem with the shift lock is it ? (I'm just checking to make sure I'm not missing something simple) Does anybody know what's going on, or will I need to be rebuilding my transmission soon ?
Old Jul 16, 2007 | 11:19 AM
mod or sell?
yours sounds like a shifter bushing issue
Old Jul 16, 2007 | 11:38 AM
Greeny's Avatar
¯\(°_o)/¯
+1 on shifter bushing max freak..
Click--> http://forums.maxima.org/oldthread.p...hifter+bushing
Old Jul 16, 2007 | 01:37 PM
max_freak's Avatar
Thanks for your input guys. Those links described my problem exactly, time to jack up the car this weekend...
Old Jul 16, 2007 | 03:50 PM
Pearl93VE's Avatar
I can has?
on the other shifter bushing: the one that connects the shifter arm to the tranny. Is that accessible from in the car? I figured it wouldn't be, but it can't hurt checking since it sounds like it could save some time if it was.
Old Jul 16, 2007 | 06:22 PM
maxitech's Avatar
Must be a blown tranny...time for a 5-speed swap...
Old Jul 18, 2007 | 07:46 PM
Sevorg1's Avatar
So I asked what fuse controlled this function. then I notice on another post that the same circuit operates the brake lights. turns out I have had no brake lights for like two weeks. Anyway put new fuse in and it blows. so I'm thinkin fuggin A. I get a schematic from a buddy of mine and go to troubleshooting (helps out having an electrical degree) any way turns out to be a brake light bulb. The two posts (on the bulb) have corroded together creating a short. New bulb problem fixed. And to think that I bought $25 dollars worth of bulbs and fuses. I returned the unused bulbs so like 12 bucks all together not bad coulda been worse
Old Jul 18, 2007 | 08:25 PM
maxitech's Avatar
Glad everything worked out for ya!
Old Jul 20, 2007 | 02:55 PM
milorad's Avatar
ok i have a similar problem ..94 automatic when shifting into drive.. it blows a fuse for my instrument cluster.. the speedometer temp-guage and all gauges but gas go out, and it engages the shift lock.. to where i cant get it out of park.. when i replace the fuse and run it through the gears it only blows when in
D...
ill try and check other fuses to see whats going on.. but any aditional or info on this.. i checked the links to other threads and couldnt find anyone with the same issue with the cluster going out.. and the fuse blowing when shifts into D
Old Jul 20, 2007 | 10:42 PM
gapboi210's Avatar
D...
Check that it the shifter isn't pulling on some wiring like maybe the light or something else. Maybe it is catching a wire when you pull it that far back.
As for the shift lock mine did something odd the other day. I was sitting in the drive-through waiting for my order. They were taking FOREVER so I decided to pop off the trim around the shifter to see what kind of bulb was in there (thinking about a color change). I pulled out the bulb and socket still attached to the wire and everything. I got back to work and could not get it into park without overriding it. Once I popped the bulb back into place under the shifter it worked perfectly and has since. Odd...
Old Jul 21, 2007 | 06:48 AM
93SCMax's Avatar
98 SE
You cannot access the shifter arm bushing from inside the car. You can only access it from under the car. Make sure you also replace the plastic bushing at the transmission, which is easily accessable from above with the hood open. This one doesn't wear out like the other, but you may as well do both while you are at it so that you know the whole linkage is secure. If I remember correctly, both bushing were under $6 total at the Nissan dealer.
James92SE
142
Jan 2, 2024 09:23 AM
ajahearn
Sep 19, 2015 03:03 PM
