electric chalenge or dumb problem
Old Jul 20, 2007 | 01:24 PM
tobinaz's Avatar
Let's see,
I didn't use my max for a few weeks and while I was using the wipers, they stopped at the middle and didn't come back again.
It would be as simple as a fuse, BUT I don't have power windows/locks to work, nor sun roof and maybe nothing in the interior. I haven't driven it cause, COMMON it's 107 in Tucson and cannot roll down my windows please help. Even to go outside and guess the failure it is too hot.
Thanks fellows!
Old Jul 20, 2007 | 10:06 PM
Hectic's Avatar
Are you sure it's not a Katrina car? That's quite a lot of problems.. Sounds like you aren't getting power to a lot of systems. Did they all go out at the same time or gradually?
Old Jul 20, 2007 | 10:18 PM
maxitech's Avatar
I've heard of that happening with Audis and GM's but never Maximas...I will see if I can come up with any relevant info...FYI, the Audi and GM problems were totally different issues.
Old Jul 21, 2007 | 07:01 AM
tobinaz's Avatar
I don't know if it is a katrina car, I had owned it for 2 years and didn't have a problem like this.
Old Jul 21, 2007 | 10:48 AM
Alex_V
Check all fuses, and check and make sure the grounds are good. IE they aren't rusted between the wire and chassis.
~Alex
Old Jul 21, 2007 | 08:21 PM
internetautomar's Avatar
mod or sell?
you probably blew a fusible link.
look under hood at the square looking fuses with a window on top
one them probably blew.
Old Jul 23, 2007 | 07:23 PM
Tquick's Avatar
That is a lot of electrical stuff not working at one time. Are you sure someone didn't steal your battery?
Check the fusible links, ground connections, positive connection at the battery, make sure one of the power wires didn't corrode, or break off the terminal there.
Old Jul 30, 2007 | 11:00 AM
tobinaz's Avatar
problem solved
ended being a cable that goes connects to positive battery cable and that was loose
thanks guys!
Old Jul 30, 2007 | 12:08 PM
Cliff Clavin's Avatar
Way out West
f--- the windows, fix the air conditioning. All Maximas come with that.
Old Jul 30, 2007 | 04:19 PM
mod or sell?
cheaper / easier to fix the windows.
knight_yyz
Nov 6, 2015 02:34 PM
