Iac???
Old Aug 7, 2007 | 07:53 PM
Black92GXE's Avatar
Boomer Sooner
Iac???
I searched and found most rough idle problems start with the IAC, along with other things..
My problem is the car idle's completely okay w/o the A/C on. Once the A/C is turned on, BOOM, the idle starts jumping -- down to about 400 then up to 600 (numbers are approximate, but it just keeps speeding up then slowing down) and back and forth... does this sound IAC related? Thanks!
Old Aug 8, 2007 | 05:54 AM
Greeny's Avatar
¯\(°_o)/¯
Yea,it may be a dirty/malfunctioning iacv,it might also be a bad maf sensor.
Maf thread link--> http://forums.maxima.org/showthread.php?t=524493
Old Aug 8, 2007 | 08:42 AM
92 Max's Avatar
Does it slow down when the compressor is on and speed up when it is off? Could be that the IAAC A/C idle up solenoid isn't working.
Old Aug 8, 2007 | 04:22 PM
Black92GXE's Avatar
Boomer Sooner
Well, like any A/C kicking on, at first it brings the idle down.. but - then it starts bouncing back and forth/idling up then down..
I thought it could be the MAF too, but it was replaced 40K miles ago (not sure if thats a long time or not...) and runs perfect w/o the A/C running... thats why I'm confused...
Old Aug 8, 2007 | 04:31 PM
whitemax89's Avatar
Its ur fuel injector cause i had the same problem thats why i loved driving with the ac on in the city. But after i replaced all of them never the same problem.
Old Aug 8, 2007 | 08:08 PM
Black92GXE's Avatar
Boomer Sooner
Why would it run fine w/o the A/C -- and to also add to it - it runs fine after a few minutes of driving or warmup. It will still swing some, but not near as much....
Old Aug 8, 2007 | 08:49 PM
CyMax's Avatar
As long as we are talking about the IAC, is there any advantage to removal and cleaning of this part?
Old Aug 8, 2007 | 09:08 PM
LvR's Avatar
LvR
Sure!
Old Aug 8, 2007 | 11:03 PM
Black92GXE's Avatar
Boomer Sooner
lol exactly... but that doesn't help my situation..lol
Old Aug 8, 2007 | 11:46 PM
LvR's Avatar
LvR
Easy - the normal range of travel of the IAC valve when the motor is warm is quite small - when the motor is cold/AC is used, and when the IAC is required to move more than the normal range, gunk can prevent/delay its correct and timeous operation - so go clean it anyway.
Old Aug 9, 2007 | 11:27 AM
Black92GXE's Avatar
Boomer Sooner
Well, I'll clean it when I install the intake spacers... will report back if it doesn't help and go from there
BkGreen97
Apr 2, 2016 05:47 AM
doobadoo
Aug 15, 2015 06:43 PM
maximabest
Feb 29, 2004 04:17 PM
CystumMax
Mar 13, 2003 09:07 PM
mango95se
Jun 8, 2002 05:17 PM
