Search function dead, knock sensor Q
Alright yes this is most likely a dumb question but the search function is dead and I was wondering if, in order to replace the knock sensor, you have to remove the lower intake manifold?
Originally Posted by MyGreenMax94
Did you find a k/s code?
If so,then yes you need to remove the upper/lower intake manifolds,also the large coolant pipe under the lower intake must be removed.
Stupid question #2 how do I pull the codes? (insert
here)
stickies have more detailed info.
but basically you turn the screw on the ECU and the 2 lights flash out the code.
Ya, NOW the search wants to work!! Thanks tho!
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
