recommended tire pressure for our cars?
Aug 18, 2007 | 06:28 AM
sorry, but what is the recommended tire pressure for our cars, is 32 psi okay on all four? Yeah, its a dumb question
Aug 18, 2007 | 07:53 AM
...there should be info on the tires AND in your maxima handbook
Aug 18, 2007 | 08:37 AM
I have mine at 38 psi I like my tires to last little longer and I dont mind the aggressive ride
Aug 18, 2007 | 10:38 AM
I keep mine mid 30's in front mid-high 30's in back.
Aug 18, 2007 | 08:11 PM
it should say in your armrest. mine says 29. seems low??
I keep mine at 35.
Aug 18, 2007 | 08:13 PM
Pressure depends on the tires you have, how you drive and what kind of a ride you want.
Most tires are either 36 psi or 44 psi maximum pressure, checked cold. The tire's weight carrying capability is acheived when the tire is inflated to its maximum.
The roughness or smoothness of the ride is controlled a little bit by the tire pressure. The lower the pressure, the softer the ride.
For the best tire wear, the front tires should have more air pressure then the rear tires because a front wheel drive car has more weight on the front tires.
Me personally, I use stock size tires. I run my front tires 6 pounds higher than the rears. My current tires are 44 psi max rated, so I run 38 in the fronts and 32 in the rear. At highter pressure, I don't like the feel when I hit a pot hole or am on rough pavement.
If you have low profile tires and don't have smooth streets, I would suggest running with the pressure on the high side to avoid flat tires from hitting pot holes.
Aug 18, 2007 | 08:14 PM
Quote: ...there should be info on the tires AND in your maxima handbook
i like that because your headline thing seems to speak to him. no offense to him.
i keep mine at like 35 or so. one leaks slowly. it has a plug in it. and um... for whatever reason i ended up with front tires who say that the max pressure is 35 so i really can't go higher.
Aug 18, 2007 | 08:19 PM
oh my gawd!!! i cant stop laughing....
Aug 18, 2007 | 09:00 PM
Quote: I have mine at 38 psi I like my tires to last little longer and I dont mind the aggressive ride
they won't last longer, but you will notice the center wearing out faster due to overinflation.
Aug 19, 2007 | 01:25 AM
ugh.........
