Transmission flush
Old Aug 23, 2007 | 11:33 AM
mikekantor's Avatar
Transmission flush
I wanted to step away from the main flood thread to deal with some of the specific issues I'm having. This one will be with the A/T.
After checking the fluid recently, I noticed it has a pinkish look to it, so water got in. I've only driven around the block after the flood, hopefully nothing was damaged in such a short time.
From what I've read, about 1/2 of the ATF stays in the torque converter. So if I replace fluid then 0.5^n would remain for n flushes, which doesnt help me much because even after draining and filling 3 times I'm still at close to 10% water-contaminated ATF.
I read there is equipment at some of the service places that hooks up directly to the cooler lines, so it drains old fluid from outgoing line and fills with new fluid into the incoming line. Midas claims to replace 95% of old ATF using this. Has anyone had a service like this done? Is it worth it or should I just do 5-6 flushes?
Old Aug 23, 2007 | 11:41 AM
internetautomar's Avatar
mod or sell?
the problem with pressure flushing is that it removes material from friction surfaces inside the trans, and can hasten a transmissions demise.
Old Aug 23, 2007 | 12:36 PM
LvR's Avatar
LvR
Other than removing and stripping the box and then cleaning everything out, the "flushing and replacing while the box is running in the car" is the best you can do ....................... 95% I don't know about but its definitely more effective in scavenging "old" liquid" from the box' internals than simple drain/replace exercises ................ if they can first have the drain-plug removed to dump the rubbish at the bottom of the box, even better
Well - the box is built with no loose parts/material when new and its obviously intended to operate like that because the box has a filter and a magnet on the sump-plug to remove any such items during normal operation ...................... so imo any "loose" material present removed during a flush/drain can only be beneficial because it can in reality serve no purpose other than causing damage to metal seal/bearing surfaces. Any friction surfaces having to rely on "loose" and therefore removable material on its surface to help it serve its purpose, renders the box' operation a crap-shoot ito predictability.
I have seen lots of people saying the same (don't flush the box it will die) .................. in the light of the above, logic dictates that there is no means of proving that the box would not have died even if the flush did not happen ...................... using the same funky logic I can actually prove exactly the opposite - ie - that draining/flushing an old worn-out box (300000km in my case) does NOT kill it ...................... but as I said that is illogical irrespective of the number of people saying it out loud.
In the end, the reality is that the box was never designed to work with "removable" material on the friction surfaces so why would such animals help the operation of the box in its old age? ......................... guess the answer could be that the "removable" material causes "gouging" in the metal friction surfaces next to the worn clutches/bands and as a result possibly extend the inevitable ......................
Old Aug 23, 2007 | 01:24 PM
mikekantor's Avatar
Well I also intend to remove the pan soon because it's gasket is leaking, and I'll clean it while off, but I'm waiting for the gasket to arrive. Also read today that the bolts have to be replaced, so I have to order those as well.
Old Aug 23, 2007 | 01:46 PM
mikekantor's Avatar
Found some interesting info during continued searching:
http://www.pecuniary.com/pdf/transmissionfluidevac.pdf
Does the VE A/T have a filter, or do the magnets act as the only filters? I've never seen a filter in diagrams.
It appears that changing fluid right now will dislodge lots of buildup, and that new circulating dirt is what would cause an expedited failure. Maybe I'll just drain and refill it once per week until it starts to come out clean, whatever I spend on fluid will be cheaper than a used or rebuilt transmission.
Old Aug 23, 2007 | 02:05 PM
Greeny's Avatar
¯\(°_o)/¯
The vg/ve transmissions have a screen,not a fiber type filter like many domestic tranmissions...
I would just drain/refill with cheapo fluid a few times(drive it a few days between changes to circulate the new fluid before changing),then fill with fresh nissanmatic-d fluid or amsoil for your final change...
Old Aug 23, 2007 | 02:25 PM
mikekantor's Avatar
Is the screen something I'll see after removing the pan, or is it in another area?
Old Aug 23, 2007 | 02:39 PM
Greeny's Avatar
¯\(°_o)/¯
Nope,it's somewhere in the valve body area iirc,not easily accessible..
Old Aug 23, 2007 | 05:14 PM
mod or sell?
nope. the VE has one that you'll see once you drop the pan.
LvR- I do know what I am referring to and I ASSuME that you haven't been inside a trans after it's been flushed or seen what happens to a trans along it's life span. I have and it's much more fragile than you make it sound.
trust me, don't power flush.
Old Aug 23, 2007 | 05:25 PM
Greeny's Avatar
¯\(°_o)/¯
Is it in the control valve assembly?
Old Aug 23, 2007 | 05:37 PM
mod or sell?
nope, it's in the normal location.
Drop the pan
remove some cross bar (4 bolts IIRC)
and the filter drops out.
or something like that.
I did it on my first vE after I smacked the trans pan into a curb.
Old Aug 23, 2007 | 05:41 PM
Greeny's Avatar
¯\(°_o)/¯
Drop the pan
The control valve assembly is the first thing you will see when you drop the pan?
Old Aug 23, 2007 | 05:49 PM
mod or sell?
me thinks that pic is wrong.
Old Aug 23, 2007 | 05:52 PM
Greeny's Avatar
¯\(°_o)/¯
AT-242 in the fsm is the RE4F04V auto trans exploded view...So who or what is wrong?
Old Aug 23, 2007 | 06:08 PM
mod or sell?
it doesn't show the filter that is attached to the bottom of the control valve assembly.
they call it an oil strainer.
Old Aug 23, 2007 | 06:15 PM
mod or sell?
http://www.transtarindustries.com/ca...oad.asp?ID=359
shows it much more clearly.
Like I said, I know it's there, I replaced it on mine.
and when you go into a parts store they will sell you a filter kit ATP # B-151
Old Aug 23, 2007 | 06:16 PM
mod or sell?
also look in the FSM under the section control valve disassembly they show it there. I just don't have the PDF on my PC anymore so I can't put up a pic.
Old Aug 23, 2007 | 06:22 PM
Greeny's Avatar
¯\(°_o)/¯
Ok, found it..
Old Aug 23, 2007 | 08:47 PM
Soaknfused's Avatar
FWIW
The service that is offered at most quick lubes etc are very similiar. I manage one so I can tell you for sure that there is a substantial difference between a transmission flush and a transmission fluid exchange.. Using the machine we, and most others use does not put any pressure into the transmission, it is a one for one "exchange" that takes place by seperating the line where it goes into the cooler and with the engine running, it uses the transmission pump to push the old fluid out, thus pushing the new fluid into the trans.. this does replace over 95% of the fluid in the transmission and will not do anything to the transmission internally that it won't do to itself under normal operation. Hope this clears up things a bit.
My max has had this service done every 30,000 miles or less since new and at 150,000 I still continue to do it. Only time it can cause any trouble is on a vehicle with a transmission that is so shot that the only thing holding things together is the extra grit that would be in 15 year old fluid that has never been changed, in that case.. if its never been done before, exchanging that fluid can bring underlying troubles to the service.. not breaking it just taking away its crutch (transhy, broken down grit filled fluid)
Old Aug 23, 2007 | 10:02 PM
LvR's Avatar
LvR
As do I my friend and I certainly appreciate the fragility of the animal.
We seem to forever be holding different approaches to anything and everything we talk about - the difference is that I have technical arguments to substantiate my position whereas you simply ask me to trust you ................... and once again in a situation where I actually do have the experience you may think I don't.
Its as simple as this:
Worn transmission components' life cannot be extended beyond the point where they no longer operate as designed - and certainly not by the addition of worn box materials circulating in the oil. If you happen to drain /flush the ATF and the box fails, then the box was already dying/dead to begin with - having to rely on the presence of crap in the oil to make friction surfaces work as designed (in effect what you are advocating when you say "removes material from friction surfaces inside the trans") is a crap-shoot ito prolonging box life.
If you have removable material on the friction surfaces in the box (due to wear) they will get released into the oil during normal operation anyway.....................
As soaknfused said there too - the "power flushing" is a bull****-baffles-brains term used by unscrupulous operators to trick the vehicle owners into thinking that there is some kind of "pressure cleaning" performed in the operation when all they actually do is to replace all the oil circulating through the cooler by the operation of the box at its normal levels/modes.
A power-flush can only affect the oil and the flow of it in the box by means of the cooler return and feed lines - In reality, the oil pump's construction and the pressure regulator valve in the box prevent any kind of abnormal flow to get into the box via the cooler feed line without the box being completely cracked open and the operation done from inside the exposed box's components with some kind of pressurized nozzle forcing oil into crevices. As for the cooler return line - no use putting pressure on there higher than what the box's pump can send down the cooler feed line - if you do, you simply overfill the box and cause a mess
Net result is there is in reality no pressure entering the box other than what its normally been operating at - so where exactly is the problem?
Old Aug 24, 2007 | 05:43 AM
mod or sell?
you can have your opinion, I will have my 10+ yrs experience.
I've seen way too many cars come in after a power flush with a blown trans to ignore it.
If you look at the composition of a friction plate you realize that it can very easily lose the friction material from the plate if too much pressure is applied.
most trans flush machines do a reverse flush which means that the pressure doesn't see the "relief" valve until after it has hit the friction plates.
Old Aug 24, 2007 | 07:30 AM
LvR's Avatar
LvR
So with even the worst case design of even a reverse flow flushing rig you intend applying more "pressure" to the friction material than the box's own mechanical bands/solnoids/cams can? - go on pull the other one.
The box's design during normal operation is comfortabily applying orders more pressure to the friction material than what the oilpump/relief valve combination can create via the ATF.
Rubbish! - till the relief valve actually "see" the ATF coming from your suggested "reverse flow flushing machine" there simply is no mentionable pressure anywhere on that hydraulic line at all - you cannot have pressure if the line is not filled - and if the line is eventually filled, the pressure difference between the relief valve and the feed coming from the funky reverse flow flushing machine will be so close to zero that its just not funny.
Lets agree to disagree now - you are simply not making sense - irrespective of 10+ years of experience (which happens to be not much less than my own in the this particular field btw)
Old Aug 24, 2007 | 07:49 AM
mikekantor's Avatar
I dont know if either of you read the PDF I posted above, but in it, the claim is that the infusion of new fluid after a long time with old fluid puts a lot of dirt into the filter/screen.
So if the screen is cleaned soon after, and maybe again a few weeks later, then everything will be fine. Otherwise it gets clogged, and parts which need lubrication and cooling dont get it, so the tranny fails. I plan on doing this, so after I get the water contamination out, I am going to clean the pan, magnet, and clean or replace the screen. Then do it again after a week or two of light driving, and then possibly another time soon after, because I think my transmission still has factory atf in it. I know I know, its bad, but for a long time my maintenance was of a responsive nature as opposed to preventative. And I think the owners manual says to only change ATF if driving at heavy loads, and often in high-dirt areas, so I ignored it.
Old Aug 24, 2007 | 08:17 AM
Alex_V
Originally Posted by LvR
The transmission was also designed to have regular flushes, not every 100-150K, alot more regularly then that. After its in there long enough it should just stay pretty much. But I didn't really mess with that I just went with a 5speed swap since my tranny was toast.
~Alex
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
