cleaning iacv, do i need to buy a gasket first?
Old Aug 30, 2007 | 06:27 PM
cachejob's Avatar
i have a 92 se. i've read lots of threads suggesting cleaning the iacv as a good cheap way to potentially tune up the idle a bit. none of the threads i've seen mention buying a gasket. is there one that needs to be replaced when i take the iacv off to clean? the 2 nissan dealers closest to me are an hour each way, so i'd like to order it ahead of time if that's the case. i couldn't find a reference to any gasket or seal in the fsm, but just to be on the safe side...
Old Aug 30, 2007 | 06:52 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yes there is a gasket, and yes you should have one, unless you really trust silicone gasket material stuff.
Old Aug 30, 2007 | 06:54 PM
Greeny's Avatar
¯\(°_o)/¯
Yup,there is a gasket you need to buy(not sure on the part # though)
Be sure to get all of the old gasket off before you put it back together.
Edit Cape beat me
Old Aug 30, 2007 | 06:57 PM
92 Max's Avatar
They're cheap or you can make one out of gasket paper, just keep the old shards to match. Take a picture of the old one on the IACV. There is an orientation to putting it back on.
Old Aug 30, 2007 | 07:30 PM
I don't have a gasket. I have a phenolic intake spacer, and black silicone on each side. But that's just because of the spacer. Same goes for my TB and dualduct. No gaskets there either.
Old Aug 30, 2007 | 09:37 PM
cachejob's Avatar
thanks guys
Old Aug 31, 2007 | 06:58 AM
Cliff Clavin's Avatar
Way out West
They only cost a few bucks at the dealership, but I would make sure you have one in your hand before removing your IACV. No dealers in my area had one in stock and I had to wait several days for one to arrive from California.
I made the mistake of removing the TB and IACV, then going to the dealer to get the gaskets. The car sat in the garage until IACV came in.
Old Aug 31, 2007 | 07:00 PM
cachejob's Avatar
ordered a gasket today, $10.25 Canadian. not bad at all. while on the phone with the dealer i priced out anti-squeal hardware for brakes (metal shims). they want $66 each set, front and rear. ouch. internetautomar, do you stock those shims? couldn't find them on your site.
Old Aug 31, 2007 | 07:34 PM
redwood_usa's Avatar
The better quality brake pads come with metal shims attached. You dont need to buy seperate shims.
Old Aug 31, 2007 | 08:55 PM
cachejob's Avatar
i've seen pad sets with the backing shim attached, but never seen the shims included that the pads slide along.
Old Sep 1, 2007 | 09:21 AM
hadman's Avatar
Hey Cachejob, can you tell me the part # on the gasket you ordered? I need one as well.
Old Sep 1, 2007 | 11:01 AM
cachejob's Avatar
didn't get a part #, just asked the dealer for the iacv gasket.
Old Sep 2, 2007 | 06:13 AM
internetautomar's Avatar
mod or sell?
are you talking about these :
Old Sep 2, 2007 | 09:35 AM
cachejob's Avatar
those are the ones. sent you a pm internetautomar.
Old Sep 3, 2007 | 09:40 AM
Deman1134's Avatar
i have a 1992 GXE, do i need to buy a gasket if i clean the TB or is that only on the SE's?
Old Sep 3, 2007 | 10:31 AM
Pearl93VE's Avatar
I can has?
Yes, you need a gasket.
Old Sep 3, 2007 | 11:48 AM
Alex_V
you can clean the TB w/o taking it off. On the 92-94 SE's you have to take the TB off to clean the IACV but not on any other 3rd gen.
So for your car you need an IACV gasket to clean both the TB and IACV.
~Alex
Old Sep 3, 2007 | 02:19 PM
cachejob's Avatar
~Alex
doh! does that mean i need to be ordering a gasket for the throttle body as well if i plan to clean the iacv on a 92 se? iacv gasket's on the way.
Old Sep 3, 2007 | 02:34 PM
Alex_V
wait, what maxima do you have? DOHC or SOHC?
~Alex
Old Sep 3, 2007 | 04:04 PM
Greeny's Avatar
¯\(°_o)/¯
Wake up you 2 (alex,read his info under his screename)
The iacv/throttle body are 2 separtate items on both ve/vg engines,you do not have to buy a gasket to clean the t/b on a ve engine,just spray t/b cleaner into the t/b..
To the OP: Stay with your original plans with the iacv gasket,but you do not have to buy a t/b gasket if you are just going to clean it..
~Alex
Old Sep 3, 2007 | 04:15 PM
cachejob's Avatar
i didn't think i needed to take off the tb to get at the iacv, but his post had me wondering. i was hoping to avoid confusing by stating in my original post which year/model it was. thanks.
Old Sep 3, 2007 | 06:14 PM
Pearl93VE's Avatar
I can has?
sorry, I was posting for Deman1134.
Old Sep 3, 2007 | 06:37 PM
Deman1134's Avatar
so 94 maxshima, theres no way i can clean it w/o buyi n a gasket? even if i just spray cleaner into it without takin it off?
Old Sep 3, 2007 | 06:44 PM
Pearl93VE's Avatar
I can has?
You could but I wouldn't recommend it. It's better just to take the three bolts off, clean IN the throttle body (Not just the lower Intake Manifold) Clean out the lower intake manifold and replace gaskets and put it all back. It's just better practice and you know you won't have to worry about it down the road.
Old Sep 3, 2007 | 09:59 PM
Alex_V
I swear when I posted at 1:48 it said 92 gxe under his name. I double checked before I posted too....
~Alex
Old Sep 6, 2007 | 07:05 PM
92gxe/cg2's Avatar
where can i buy the TB gasket for my 1992 GXE? I havent cleaned or touched the TB yet but when i clean it il need the gasket. Thanks
Old Sep 6, 2007 | 08:36 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Forgive my ignorance, but what is an IACV? and where is it?
Old Sep 7, 2007 | 07:15 AM
mod or sell?
Idle Air Control Valve
Idle Speed Control Motor
Throttle Air Bypass Valve
Old Apr 13, 2008 | 09:00 AM
KillaKarebear's Avatar
I dont know if the iacv gasket part number for the vg is the same for everywhere but for Nissan of America it is 23785-21V140 so if anyone needs to replace it instead of giving your vin # to get it.
IACV gasket part number: 29785-21V140
Old Apr 13, 2008 | 01:23 PM
mikekantor's Avatar
As long as this is back up... VE IACV gasket is 23785-97E00
The Wizard
24
Oct 1, 2015 08:47 PM
aminus21
Sep 12, 2015 04:53 PM
crazyespn
Sep 3, 2015 01:30 PM
iflexsteel
Sep 2, 2015 08:04 AM
