Cooling Fans
Old Sep 4, 2007 | 11:02 PM
majordan's Avatar
Cooling Fans
My fans are slowly dying. Their bearings are starting to squeal louder and louder. Is it cheaper to replace/fix the motors or do I need to replace the whole fan assembly.......
tks in advance......
Old Sep 4, 2007 | 11:12 PM
ColombianMax's Avatar
I belive you can go to an autoparts store and just get the fan motor...IIRC, they usually run about 30 bucks for the average american car. You can probably just pick up the whole fan assembly for that much at the JY and just bolt on a couple of 10mm bolts.
Old Sep 4, 2007 | 11:17 PM
majordan's Avatar
Will an American fan motor work on a Japanese car........
Old Sep 4, 2007 | 11:31 PM
Greeny's Avatar
¯\(°_o)/¯
The motors are close to $100 each at autozone. yeah expensive as these motors rarely go out on 3rd gens...
I suggest not trying to jury rig a different motor in their place as you might run into electrical compatiability issues. As already stated your best bet would be to find a local salvage yard for a replacement cooling fan assembly.
Old Sep 5, 2007 | 12:21 AM
gapboi210's Avatar
If u go to the junk yard just make sure the blades spin freely and see if you can wobble the blade up and down. Should be tight and turn smoothly. I usually look for one with the lowest mileage.
Old Sep 5, 2007 | 07:24 AM
internetautomar's Avatar
mod or sell?
I've got the whole assembly brand new for $100
Old Sep 7, 2007 | 05:42 AM
majordan's Avatar
I wish I had known about the $100.00 offer sooner. I replaced both motors. A easy job!!!!! The car runs a whole lot better. I always thought that squealing noise was coming from the compressor, but I was wrong.
Old Sep 7, 2007 | 07:20 AM
Yes it is an easy job How much did you pay for the fans?
Old Sep 7, 2007 | 08:12 AM
majordan's Avatar
I paid $180.00 for both motors, even though only the passenger side was bad.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
