tension pully noise
Old Jul 22, 2001 | 01:08 PM
mipinc's Avatar
I just got the timming belt/water pump repalced. Now when I turn on the aircondition I get a clicking sound fron tension/compressor pully. The car also fell jerky with the noise. The noise go away sometime and then come back. A/C air is coming out cold. I was told it was the bad compressor. I thinks it is the bearing between the tension and compressor pully.What could the cause of this? How can I fix this? If i need to get it fixed from mechanics then how much should it cost?
Old Jul 23, 2001 | 06:16 AM
Richy92SE's Avatar
Its your bearing from the tension pulley just replace it its like 10 dlls I think, its easy to take it off, just loosen the bolt on top of the pulley this will releave the tension then loosen the bolt of the pulley. I think you will have to use a press in order to get the bearing off of the pulley.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
