How to tell if power antenna is Working
Old Sep 6, 2007 | 09:18 PM
92gxe/cg2's Avatar
So the other day the antenna made a loud noise and now doesnt work. well thats not too bad i can play cds but id like to fix it. Is ther a way i can test if the motors good or not? Im guessing its not but if i dont have to buy one i dont want too. If i go to the junkyard and get one wat years will fit my 92? will all 89-94s or what?Also i hear no noise when i put the radio on so the gear in there is probably fine.
Old Sep 6, 2007 | 10:00 PM
Pearl93VE's Avatar
I can has?
If you can hear the motor working when you turn on your car/ radio your antenna motor works. Usually the motor outlives the antenna mast by a long time and I'm guessing that's what's wrong with yours.
Get on ebay and search for 1989-1994 Nissan Maxima Antenna and you'll find one for like $30. Chances are the junkyard one's are bad as well.
Old Sep 6, 2007 | 10:04 PM
ColombianMax's Avatar
hey where in chicago are you located?....just outta curiousity
Old Sep 7, 2007 | 05:36 AM
majordan's Avatar
How hard is it to replace the mast only?
Old Sep 7, 2007 | 07:24 AM
92gxe/cg2's Avatar
im right off harlem and irving, how bout urself?
well i hear no noise when turning the car on so is the antenna garbage? If i went to a junkyard (which i have and have seen what ;looked liek a good antenna) how would i check to see if it worked if thats possible?
Old Sep 7, 2007 | 07:26 AM
Dude! you're like 5 minutes from my house, I'm by Central Ave
Oh and for the JY antenna, you'll be lucky if you get one. I live at the JY and I havent seen any good ones
Old Sep 7, 2007 | 07:35 AM
92gxe/cg2's Avatar
damn, central and what, i used to go to portage park all the time.
well anyways when i was at victory (not the greatest place) they had one that i pulled from a max and it had tension in the antenna meaning that gear wasnt broke but i didnt wanna chance it and buy it.
MikesChevelle
Nov 23, 2024 11:17 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
