Just did a transmission drain and refill
Old Sep 7, 2007 | 04:15 PM
gapboi210's Avatar
My transmission shifts excellent. I have heard how these automatics are kinda weak and prone to fail. My fluid was dark and I wanted to keep it shifting good so i did a drain and refill. Didn't want to flush since I am unsure of the last if any service the tranny had and I am at 120K. Mine doesn't have a pan on the bottom just a plug on the tranny. That b1tch was so tight I had to use a hammer on the ratchet to break it loose. It drained about 3 quarts out. I put a quart of Lucas and the rest just D/M. I think the plug was half stripped cause I coated it with teflon tape and tightened it back up, but it didn't seem to wanna get tight like it was before. I got it pretty snug so I will leave it be and check it from time to time. Man, this thing shifts like butter now. You can't even feel the shifts.
Old Sep 7, 2007 | 04:30 PM
Greeny's Avatar
¯\(°_o)/¯
Please do this next..
http://forums.maxima.org/showthread.php?t=405266
Old Sep 7, 2007 | 05:15 PM
gapboi210's Avatar
yeah seems pretty easy. probably take the line coming out of the radiator and make that the inlet for external cooler then the out from the cooler to the tranny. so hopefully the fluid will cool off some in the radiator and then hit the external cooler for additional cooling.
Old Sep 7, 2007 | 05:26 PM
gapboi210's Avatar
btw i swear that my last VG had a pan on the bottom for the tranny with a plug. this one doesn't. just had a plug directly on the tranny. so there was no pan to drop to access any screen or filter.
Old Oct 2, 2007 | 07:22 PM
starkviller's Avatar
what kind of tool do you use to get the drain plug out? what size?
Old Oct 2, 2007 | 07:59 PM
LvR's Avatar
LvR
Originally Posted by MyGreenMax94
Linky no worky - 3/10/2007 5AM (GMT+2)
Old Oct 2, 2007 | 08:22 PM
Pearl93VE's Avatar
I can has?
user 11122324
42
Jul 18, 2022 03:35 PM
Forge277
Jun 13, 2016 09:26 PM
Pied
Sep 26, 2015 03:29 PM
