89 Max ABS Pump Over Ride
Old Sep 9, 2007 | 11:29 AM
shiftnatredline's Avatar
Godzilla
So far its not going so well. I put T splitters on the front and rear pipes from the master cylinder. The front hose goes to the front brakes and the rear go to the rear.
The problem is after driving the car for about 5 miles they lock up. I'm thinking the brake fluid is getting so hot its boiling and expanding causing more pressure to build up and push on the calipers.. This would only happen if the valves in the master cylinder weren't opening to relieve the pressure.. eh idk anymore..
anyone done this before/have any ideas?
Old Sep 9, 2007 | 12:07 PM
internetautomar's Avatar
mod or sell?
1. we have covered this discussion before
2. I believe you need to change the master over and that you have it plumbed wrong.
Old Sep 9, 2007 | 12:22 PM
Godzilla
Right, well I just went through and looked at all the pages for anything on over riding the pump and i didn't see anything. could you post me a link??
i'm very sure they're run correctly. so if i put a non abs master cylinder on it that will fix it? i know the current one only has two pressure lines but a non abs cylinder has four so it has the perportioning valve in it already... that may be my problem... hmmmm
Old Sep 9, 2007 | 12:29 PM
mod or sell?
http://forums.maxima.org/showthread....&highlight=ABS
I also believe they are run diagonal not front to rear
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
maximusrising
Sep 2, 2015 09:55 AM
