need help identifying this part.
Old Sep 9, 2007 | 06:15 PM
ustfdes's Avatar
- Product of Maxima.org -
located on the front of the transmission, looks like some kind of solenoid, but i'm not sure what for...
Old Sep 9, 2007 | 06:27 PM
Greeny's Avatar
¯\(°_o)/¯
Clutch slave cylinder..
When you push your clutch pedal in,the fluid you push through the lines ends up at this unit.Then this slave cylinder pushes a "rod",this rod operates a shift fork inside the bell housing of your transmission,the shift fork pushes the throwout bearing down on to the pressure plate located on your flywheel,this disengages the clutch friction plate from the flywheel contact surface.
Old Sep 9, 2007 | 06:42 PM
ustfdes's Avatar
oh ok, had no idea what that was, and had no idea how a slave cylinder worked....thank you sir, tis much appreciated.
D Mason
Jun 21, 2016 04:43 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
followthadollar
Sep 13, 2015 09:55 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Colossus
Sep 9, 2015 05:46 AM
