Electrical Problem
Old Sep 10, 2007 | 12:03 AM
93MaxMurf's Avatar
Electrical Problem
I have a little bit of a problem. It started probably about a year ago when i got into my car at night, turned on the head lights and the gauge lights and and shifter lights did not turn on(later found out tail lights were out as well). looked at the fuse, saw it was blown so i replaced it. They worked fine for about 2 days then the fuse blew again. I decided to do a quick fix and just use a bigger (20amp) fuse. After about a month, that fuse blew as well. tried fixing my stereo wires making sure none were touching and everything was grounded as well as my rear speakers. everything seemed fine. made sure all the wires were connected correctly on the speedo. everything was normal. I was wondering if anyone else has had this problem or if anyone knows what it could possibly be?
thanks for the help.
Old Sep 10, 2007 | 05:29 AM
Greeny's Avatar
¯\(°_o)/¯
I'm thinking rear taillight bulb housing corrosion may be your problem,not sure though..
Take a good look at the rear taillight bulb units for any whiteish/greenish stuff around the bulbs and/or electrical connections..
knight_yyz
Nov 6, 2015 02:34 PM
