VTC - Technical Service Bulletin (TSB) #NTB-95-022
Old Jul 23, 2001 | 06:39 AM
psyclotran's Avatar
Any one has a copy of this they can share?
I am get getting anywhere with these local Nissan dealers around here in Michigan.
Old Jul 23, 2001 | 08:10 AM
psyclotran's Avatar
oops
I should check before hitting the submit button.
I cannot get this information from the dealer. They said that this information is NOT available to the public.
Old Jul 23, 2001 | 08:50 AM
Jeff92se's Avatar
I'm needing a caw
That's bull****. Go to AllData's website and grab their info. Then go to the local library and ask for the AllData disk for your year car. Then look it up and print it out. You might only have to go to the library becuase you already have the numbers. BTW there are two TSB's on this.
Old Jul 23, 2001 | 08:52 AM
Matt93SE's Avatar
STFU n00b!
Try your local library.. someone told me this stuff is available there.
Your dealer is being an a$$ about it. there are many dealers that will let you see the TSBs if you ask for them, but usually they have to determine that you're competent first (i.e. not some idiot that's gonna blow up the engine trying something they read).
Old Jul 23, 2001 | 04:39 PM
psyclotran's Avatar
Thank you
Thanks guys..
It took eight tries before I found a library with this database access.
I cannot seem to find the other TSB. Please ID it for me if possible, looks like I will have to come back to the libary again tomorrow.
Thanks a bunch..
Old Jul 23, 2001 | 05:10 PM
RosenKen's Avatar
Where in Michigan are you?
Old Jul 24, 2001 | 08:06 AM
psyclotran's Avatar
Nice car, it looks exactly like mine except mine has tan leather. Where did you get the sway bar and how long ago? Did you have to make any mods to make the bars fit?
I am in the land of Ford Motor Company.. Dearborn, Michigan.
I have in my possession the TSB for the VTC.. I am going to the library to get the other TSB and I will have the complete set. Unfortunately, it is not free to print at the library but I consider paying the library a good cause.
If anyone needs a copy of this, let me know. I can scan it in and convert it to a PDF. If anyone got cyberspace, they can post this pdf for all to use when needed.
I studied the information last night. It is not an easy task. I order the service manual yesterday and arm with these resources, I will proceed with this challenge.
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
Excalibur23
Oct 13, 2015 04:33 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max8
Sep 22, 2015 02:53 PM
