Buying 3rd Gen, problem areas?
Old Oct 20, 2000 | 05:59 PM
I am looking at 3rd gen Max's with 5 speeds and I was wondering if any of you can tell me what problems I should look for and if any years were good or bad?
Car will be daily driver and weekend auto cross
Thanks in advance
Old Oct 20, 2000 | 08:42 PM
[QUOTE]Originally posted by granby5023
[I]I am looking at 3rd gen Max's with 5 speeds and I was wondering if any of you can tell me what problems I should look for and if any years were good or bad?
Transmissions, exhaust manifold studs, injectors. You may never have to work on any of these but they are fairly commonly reported. Change all!! the fluids asap. Good Luck...these cars are well built!!
Old Oct 20, 2000 | 09:04 PM
JDwyer2821's Avatar
If the maxima has a bose system, check the speakers and amps, also the antena. The locking ignition is a b*tch on some maximas too. Thats the main things that went wrong with my max.I don't know if those affected anybody else but it does not hurt to check.
Old Oct 23, 2000 | 08:45 AM
sTAE's Avatar
The only problem I've had was with the door locks not working...otherwise it's been trouble free for the 3 years that I've had mine.
Old Oct 23, 2000 | 11:00 AM
DDD
My 3 year experience:
PROBLEM SOLUTION
1. Rattling sunroof Don't know
2. Leaky water pump Try lubricating coolant
additive
3. Rusty fuel filling tube
under the plastic cover Use anti-rust
4. Rattle in steering column Repair
5. Slow power windows in winter Use silicon spray
In general, 3rd Gen. Max is a best choice. Wonderful reliability and power. Please note - avoid VE30DE engine, choose VG30E one. Good luck !
Old Oct 23, 2000 | 11:25 AM
sTAE's Avatar
Say huh?
Originally posted by DDD
.......Please note - avoid VE30DE engine, choose VG30E one. Good luck !
What's wrong with the VE30DE? Is VG30E better? And why?
Old Oct 23, 2000 | 11:32 AM
Jeff92se's Avatar
I'm needing a caw
Yeah avoid 190hp vs 160 hp-->
I have no VTC or stud problems.
PROBLEM SOLUTION
additive
Old Oct 23, 2000 | 12:21 PM
DDD
VE30DE vs VG30E
I've read A LOT of claims regarding problems with VTC and big bucks for it's repair. At the same time VGE accelerates Max like a jet without those additional 30 hp.
Hope your VE is well.
Regards,
DDD
Old Oct 23, 2000 | 02:15 PM
James92SE's Avatar
2 VE's are better than one!
i have had no vtc problems or stud problems. my family has had the car since 93. i doubt that there was any problems with the vtc's or stud problems in the year we didnt own it. so not all ve's have those problems.
Old Oct 23, 2000 | 02:25 PM
Jeff92se's Avatar
I'm needing a caw
Re: VE30DE vs VG30E
Alot of those claims are probably from me since I'm one of the few who have replaced my VTC and studs as a diy project 2 years ago. Vg max have grunt down low, ve has decent grunt down low but has breathing and revs up high ie.. 6,800 rpm.
Regards,
DDD
Old Oct 23, 2000 | 02:27 PM
whitymax's Avatar
i have not had any problems either. (knock on wood) i do not have the se. my max is also a 93.
Old Oct 23, 2000 | 02:28 PM
Matt93SE's Avatar
STFU n00b!
PROBLEM SOLUTION
additive
The fuel filling tube rust problem was "fixed" by a recall not too long ago. Contact your local dealer for info on it.
just thought I'd let ya know.
stevesmax
Dec 17, 2020 11:57 AM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
