How do you remove the backseat???
Alright here goes
1st push back and then pull up the bottom seat cushion. next there are 4 bolts that--- one on each of the ends of the top cushion (you will have to push back the cushion alittle to see then. they are in the middle between the top and bottom of the cushion.) and two behind the arm rest behind the two caps. then after that push the top cushion up and take out of the car. then pull the top top peice toward you and you are done.
Good Luck
Patrick
Good Luck
Patrick
BTW...Be Careful when you take off the back panel and see a metal piece supporting the backrest and it's going from left to right (as compared to up and down). Anyways, the edges of that metal piece is VERY sharp so be cautious.
my03maxima
04-29-2020 12:48 AM
RealityCheck
10-02-2015 06:34 PM
