check engin light
Old Aug 1, 2001 | 06:08 PM
mipinc's Avatar
I got check enging light last winter. ECU code is 32 which is problem with EGR valve. The valve is ok but no suction to pull it up. I have replaced the coolent sensor but the light is there. Help!
Old Aug 1, 2001 | 09:13 PM
MadMaxBrent's Avatar
From memory the EGR valve works on the vacuum in the intake manifold (although some do work on pressure). The valve should only open at open throttle conditions. The code could be because the valve is either open or closed. Check that the tube from the valve to the intake is clear. You may need a clean of the intake which you can do yourself. Also check that the valve fully closes with no vacuum applied.
Brent.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
