camber adjustment??
Old Aug 21, 2001 | 10:04 PM
crowghost's Avatar
If I were to order some Intrax lowering springs would I need a camber adjustment to prevent uneven tire wear? or do i even have to worry about that? thanks for your help.
Old Aug 21, 2001 | 11:29 PM
MAX/OD's Avatar
yes you will need the ingalls camber bolts anytime you drop the car below a inch it leaves the camber out of spec.The bolts allow up to 3 degrees of camber good luck.
Old Aug 21, 2001 | 11:50 PM
crowghost's Avatar
Thanx MAX/OD
Old Aug 22, 2001 | 07:08 AM
Matt93SE's Avatar
STFU n00b!
Those bolts only allow +- 1 degree of adjustment. there are other aftermarket camber kits out there that can offer up to +-3 degrees of adjustment, but they're about $300/set. the Ingalls bolts are about $30/set.
Old Aug 22, 2001 | 04:18 PM
James92SE's Avatar
2 VE's are better than one!
go for the specialty products kit. they are the bolts and offer +/- 1.75 degrees of adjustment. they are only $30 too, i'll be ordering some soon. www.specprod.com
Old Aug 22, 2001 | 07:25 PM
ngthing's Avatar
if I get an alignment at a tire place, will that be enough to put the car back into spec? or will I need to purchase the bolts?
Old Aug 22, 2001 | 10:32 PM
Matt93SE's Avatar
STFU n00b!
Jon, no... the only thing an alignment shop can do is adjust toe-in/out without camber bolts or plates. stock suspension does not allow any adjustment on camber.
Old Aug 23, 2001 | 12:29 AM
ngthing's Avatar
Thanks Matt. Where do these camber bolts attach at? Is it something I could stick on myself, and take to the shop to have adjusted?
also, when I was chceking out the link above, I noticed two sets of camber bolts, one for the front, one for the rear. Are both needed? and are the setes priced as front/rear together or as front and rear seperate?
Old Aug 26, 2001 | 11:39 AM
Kraus91SE's Avatar
Will any of these kits be able to correct the camber, or will they still be a little of.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
