bose bypassing options?
Old Aug 20, 2001 | 09:23 PM
gotmilk2000's Avatar
I read somewhere on a maxima website that its possible to bypass the amps (front /back) on the bose systems. That it was just not as loud but played fine nontheless. Is this possible or was i just dreaming it? FYI...It was for using the stock headunit also. Thanks, charles
Old Aug 20, 2001 | 10:32 PM
93 SE's Avatar
i think you misunderstood what you read
if your using the stock bose head unit you dont bypass the amps,if you bought a new aftermarket head ,then you would want to bypass amps....an aftermarket h/u will work with bose speakers but will give you problems later on ,what people do is put new speakers in,and need to bypass the bose amp ,you bypass it by not using the 2 thick black and red wires going to each amp,other two left over are speaker wires
Old Aug 23, 2001 | 09:35 AM
TB-MaxSE-89's Avatar
Re: i think you misunderstood what you read
I have a new aftermarket head and 6x9's, are you saying that I can hook up my bose amps to them is so can you tell me how. thank you
Old Aug 26, 2001 | 10:37 AM
89auto's Avatar
Re: Re: i think you misunderstood what you read
Just added a JVC headunit to my previously bose equipped maxima. kept bose speakers but bypassed amps.
works great
would NOT use bose amps on aftermarket non-bose speakers and head unit because u will be "double amping"
i was also warned about differences in ohms between the amps and speakers- but know unfortunatly little about that-so am just suggesting its something else u look into
Old Aug 26, 2001 | 11:30 AM
Maxima90SE's Avatar
BUT HOW CAN U BYPASS THE AMPS?? I JUST GOT MY 1990 MAXIMA AND BOUGHT A PANASONIC CD PLAYER. WHAT DO I HAVE TO DO TO BYPASS THE AMPS IN THE BOSE SPEAKERS. PLEASE HELP AND EXPLAIN IN DETAIL. THANKS
Old Aug 26, 2001 | 12:53 PM
93 SE's Avatar
found this on ebay which is a good option to go with (adaptor)
http://cgi.ebay.aol.com/aw-cgi/eBayI...tem=1268052395
or .... free way ... disconnect wiring harness that goes into speaker/amp box.There are 4 wires going into each speaker ,your goal is to only end up to use 2,the 2 wires you DO NOT use are the bigger size wires that are black and red ...those are for bose amps..with other 2 left over connect them directly to speaker ....any one else care to add $0.02 ,its been a while and maybe i left something out ,also maybe someone here has a page with pics
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
