WHICH ONE WORKS BETTER IN THE MAX THE NOS OR THE JWT NOS
Old Oct 26, 2000 | 06:56 PM
MILLENIUM MAX
Which system is better to use on the max b/t the nos or the jwt nos
Old Oct 27, 2000 | 02:51 AM
The Max's Avatar
If you're not using a Jacobs ignition system coupled with a Nitrous Mastermind progressive rate controller, then the JWT system is best.
Either way, if you're aiming for anything bigger than a 50 shot of NOS, get a bigger fuel pump too. Walbro's 255lph@90PSI pump rules and is just the ticket for 80+ shots - wet or dry. But in my honest opinion, best to run anything above 90hp using a wet system as the pressure needed behind the fuel injectors for a dry system would be too immense and may cause injector lock-up.
Matt93SE
May 24, 2019 02:58 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
t6378tp
Aug 24, 2015 07:03 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
kenc15
Aug 5, 2015 08:29 AM
