Need help with gauge problem!!
I have a '94 GXE and when I bought it, the temperature gauge and the fuel gauge did not work. The temp. gauge does not register at all. The fuel gauge registers 1/4 of a tank all the time. Could this be a fuse problem or do these gauges even have fuses? These two gauges may not share the same problem. Any help would be greatly appreciated.
I seriously doubt it is a fuse. With a fuse, it would be all or nothing usually and I dont think it would be the cause of that anyway.
I'm not sure what else to look for, but dont waste your time looking through all the fuses
Sorry I can't be of more help
The fuel pump sender might cause the fuel gauge not to read. For the temp guage it's either a bad connection or the temp sensor on the engine is bad. If you have a haynes or FSM there are steps to check both of these out.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
