strange headlight problem, need help!!
Old Sep 15, 2001 | 06:49 PM
matt92gxe's Avatar
ok, i've had my nokya arctic white headlights for about 6 months now, and they've worked pefect untill thursday. the driver's side keeps going out. so i'll pop my hood, wiggle around my harness, and it works fine again. today, i tried removing the bulb, and it was a pain to get out, it was stuck really bad in the harness. i finally got it out, and istalled my philips blue visions that i used to use, and they work perfect. how could that bulb mess up after working fine for months? could this still be a problem with my harness? what do you guys reccomend, i really want my "HID" look back, i hate the yellow bulbs!! help quick!!
Old Sep 15, 2001 | 08:59 PM
BIGDOG's Avatar
WEll man your connector is starting to burn out. I had this same problem with mine. If you take the bulb out and look the ground wire is starting to burn. It is from running to high wattage light bulbs. Your best bet is to replace the connector and probley get new bulbs.
BIGDOG
Old Sep 20, 2001 | 12:08 PM
matt92gxe's Avatar
can anyone post instructions on how do do this? i'm not very good w/ electronics!! help!!!!!
Old Sep 20, 2001 | 12:53 PM
konan's Avatar
Here are the part numbers for the headlight connector repair harnesses.
3 pin round style use #B4343-0UFB0
2 pin use #B4342-0UFB1
3 pin square style use #B4343-0QFFB1
See Nissan TSB#NTB01-028 regarding the repair procedure for your damaged connector.
Old Sep 20, 2001 | 04:00 PM
FroMan's Avatar
http://forums.maxima.org/search.php
^^^^^^^^^^^^^^^^^SEARCH^^^^^^^^^^^^^^^^^^^^
GLAD I COULD HELP
fRO
Old Sep 20, 2001 | 04:18 PM
ICONOCLAST's Avatar
I have had the same problem 2 times now
Matt I feel your pain I have the Nokya 9004 bulbs also and I had to replace my harnesses also for the headlights already once, and guess what it is messing up the drivers side yet again now even with new more powerful harnesses and wiring (go figure).
Jared
Old Sep 21, 2001 | 11:57 AM
matt92gxe's Avatar
did a search and couldn't find much to help me. still wondering if anyone has posted directions?
Old Sep 21, 2001 | 08:52 PM
ICONOCLAST's Avatar
you have to replace the wiring with a thicker gauge of wiring so it does not short out.
Old Sep 22, 2001 | 06:58 PM
matt92gxe's Avatar
dude, you're from lexington?!?! i read it in your profile. i am from lexingotn too!!! we need to get together sometime. the maxima scene in lex just keeps growing. some of us are planning a meet if you want to attend, im me (matt92gxe) or email me matt92gxe@yahoo.com
oh btw, is your max the one w/ the street sports banner across the top? i think i've seen it before. get back w/ me!!
Old Sep 27, 2001 | 08:07 PM
ICONOCLAST's Avatar
that's me!
I am almost always downtown every weekend. There are two 4th Gen buddies of mine who i usually hang out with down there. One is Will who owns a '96 SE Auto that is Black with Black Leather, and that wacked out Knight Rider light in the front, and the other is Bucky Howard who has the Cherry Red '96 GLE Auto with the Mille Miglia Evo II rims and multi colored front lights and tint. You should definately come down there this weekend. Many excuses for my car, i am wanting to get a Nismo front 6" strip as I am out of Streetsports now and starting a new club. On top of that some ******* hit my front drivers side corner light so I am replacing them with clears As soon as I sell some of my PA sound equipment, but I do have a rather unique 11" tall Supra style wing I have coming in the mail from James92SE on the 3rd gen forum in the next week, and will have that.
Anyways... hit me up on AOL at DJthrilla2 or drop me a ring at (859) 224-9551
Peace!
Old Sep 27, 2001 | 08:30 PM
Aaron92SE's Avatar
NWP Engineering.com
What wattage Nokya Bulbs made your sockets mess up? I currently have the regular wattage (9004 65/45W) Nokya Halogen bulbs. They are slightly blue. Will these bulbs fry my headlight wiring? Thanks.
Old Sep 27, 2001 | 08:39 PM
DaBoxSE's Avatar
Most likely not, the higher wattage bulbs tend to draw more current through the stock ground wires. You should be fine using the stock wiring, but the upgraded harness will let them run more efficiently... ie: Dimming when coming to a stop at a red light. Hope this helps.
Old Sep 27, 2001 | 11:17 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah it helps. I'm not sure if I have lights dimming at a stop. I'll check it out. Thanks for replying.
Old Sep 29, 2001 | 09:10 PM
ICONOCLAST's Avatar
harness + and -
A harness upgrade only strengthens the current if done correctly, however it is not like you are upgrading to HID compatibility with thicker cable or anything the upgrade is still just the same gauge of cable generally as stock and still using the lovely (not!) 9004 setup.
The problem lies in the grounding, and if the ground cables are not perfect it will fry the harness, thus having to replace the harness frequently.
Secondly I run Nokya 65/55 which actually run a wattage of 110/100 last time I checked. I am changing my setup though soon to the BMW headlights unless I choose to spend more money and go all out with the Hydo suspension kit I am thinking about. it is either that, or custom coilovers for me.
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
