Problem when in reverse
Old Sep 27, 2001 | 08:20 AM
max91se's Avatar
I have a 91 max se, auto,with 130,000 miles. SOmetimes when i shift it into reverse, it does not go until i move the shifter a bit. What can i do? thanks
Old Sep 27, 2001 | 08:30 AM
«§»Craig B«§»'s Avatar
could be a bad shifter bushing, but that's just my guess
you can replace it yourself by jacking up the front end and removing the heat shield from just above the catalytic converter (take the cat off if it's not too rusted on or just undo the bolts holding it to the rubber hangers so you can have some room to work around it and slide the shield out the side) and then you should be able to see where it will go and inspect your other one
http://forums.maxima.org/showthread....hifter+bushing
Old Sep 27, 2001 | 07:28 PM
Pickwick's Avatar
Backup sounds.
When I back up it tends to sound like a windup toy...Is that normal?
Old Sep 27, 2001 | 08:36 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Problem when in reverse
If you have to move every gear before it goes, it could be your shifter selector linkage . If so, very easy to fix. I had the same problem. For example, when shifting from D to R. I had to put it halfway into Park before it goes into Reverse. I just adjusted my linkage. Hope this helps.
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
