VG Thermostat Change
Old Sep 27, 2001 | 06:14 PM
blackandwhite's Avatar
To them I'm like an idol
Can anybody help with this? I am thinking about doing this myself. If it difficult?
Old Sep 27, 2001 | 10:53 PM
superdesi's Avatar
all you gotta do is remove the inlet hose. Take out the bolts and replace the thermo. It takes me about 20 min (dry time for the liquid gasket).
Old Sep 28, 2001 | 07:54 AM
Rough Idle
Okay,
I got the new thermostat in, but I have a problem. Since I did the this, my idle has been screwy. It normally sits around 700-800 RPM, but every so often, it kicks up to 1800-1900 or so for about 20-30 seconds, and then goes back down to normal.
My guesses are:
1. I stretched a belt during the install, and it is slipping, letting the idle go high.
2. I knocked something loose by accident (vacuum hose maybe).
3. I didn't burp the cooling system well enough, and their is an air pocket.
Which one of these is most likely to cause the problem I am having?
Old Sep 28, 2001 | 09:48 PM
Matt93SE's Avatar
STFU n00b!
check all your wiring connections..
you said in the other forum that the temp gauge on the dash still works, BUT.. the one for the dash gauge and the one for the engine are two different sensors. I forget which one is which on the engine, but you might have disconnected the one that goes to the ECU instead of the gauge sensor.
have fun hunting this problem down!
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
