got my APC rewire kit, i like it so far
Old Sep 27, 2001 | 07:29 PM
matt92gxe's Avatar
i am really impressed with my APC kit so far. what do you guys think of yours? my lights look brighter and more white than before. anyone had any problems after the APC kit?
thanks for any input
Old Sep 27, 2001 | 08:01 PM
ngthing's Avatar
Re: got my APC rewire kit, i like it so far
I was pleased when I got my kit. I didn't notice any differences, but I did like havinga piece of mind that my sockets and wiring wouldn't burn out!
I do have issues every now and then when I flip on the high beams...it's like the bulb is messed up because the light won't turn on. Anybody else have this problem?
Old Sep 27, 2001 | 08:35 PM
DaBoxSE's Avatar
Re: Re: got my APC rewire kit, i like it so far
I like that feeling too!
{quote]
[/QUOTE]
I have the same problem sometimes too. It sucks when you are driving down a dark road, turn on your high beams and then....nothing!! No light at all...then when I put the low beams back on, only my fog lights go on so everything look yellow I actually still have a problem with the passenger side light no coming all the way on when I turn on the headlights. I have to touch the ground wire then it turns right on. I dont get it
Good luck with the new harness. I did notice an improvement in brightness when I installed my harness. I hope you enjoy it.
Old Sep 28, 2001 | 06:30 PM
mykizism's Avatar
Re: Re: Re: got my APC rewire kit, i like it so far
{quote]
[/QUOTE]
where did you guy the apc head light wireing upgrade?
Old Sep 29, 2001 | 03:12 PM
matt92gxe's Avatar
i bought it at a local import shop here in lexington, KY called Street Sports
Old Sep 29, 2001 | 05:24 PM
Mike92GXE's Avatar
Whats the APC rewire kit and how bad is the problem with the brights? Is it easy to install? Is it for hyperwhite bulbs?
Old Sep 29, 2001 | 10:09 PM
DaBoxSE's Avatar
I got mine from www.aftermarketsource.com but it doesnt seem like that site is up anymore
Old Oct 1, 2001 | 07:16 PM
matt92gxe's Avatar
the APC rewire kit is basically just higher powered wiring and wiring harnesses for your headlights. they are not only for hyperwhite bulbs, you can use them with any bulbs, but there's really no point in having the kit unless you have bulbs that have a higher wattage. as far a the problems w/ the brights, i have no problems at all, it works fine for me. installation will take a couple hours.
the reason i had to get this kit is because my nokya bulbs melted my stock harnesses.
Old Oct 19, 2001 | 05:25 AM
phat89max's Avatar
What is the APC rewire kit I'm curious?
Old Oct 21, 2001 | 10:47 AM
Kraus91SE's Avatar
I have the opposite problem, I have no low beams.
Old Oct 21, 2001 | 08:44 PM
FitzMax's Avatar
What are all of you using for bulbs??? The APC kit should only be used with higher wattage bulbs because it is set up to allow more power to flow to the bulbs. If you are using stock bulbs then you are really not getting the full use of the harness and could possible burn out your bulbs. Try switching to higher wattage bulbs to see the full advantage of having the APC harness.
-Adam
Old Oct 22, 2001 | 09:58 AM
matt92gxe's Avatar
-Adam
i'm using nokya artic white bulbs which are 85/100w bulbs. i ended up getting the kit because the bulbs fried my stock harness.
i have had it for about 3 or 4 weeks now with no problems at all.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
