Factory Alarm Acting Stupid???
I didn't think that the alarm allowed trunk access even with the key while armed? Simply pop the trunk from inside, lock and shut door, it should still sense the open door (trunk) and automatically arm once trunk is closed.
i read on this forum one time that if someone tampers with the trunk lock that it will cause the alarm to go off. my alarm goes off sometimes with the key. my theory is that the key is most likely work down a bit and when you try to open the tunk with the worn down key it sometimes thinks someone is tampering with the lock. causing it to go off. my key is a little worn down.
my03maxima
Jul 28, 2024 07:40 AM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
