Is the manual shifter supposed to do this??
Old Oct 7, 2001 | 04:48 AM
Bman's Avatar
I've only driven my new car a few hours total so far, but one weird thing I've noticed is that whenever I apply power (in say, 4th gear, and going down the road) I can feel the shifter move slightly further into the shift gate.
Say I'm in 4th gear going down the road around town. If I give it a little gas I can feel the shifter move further rearward into the shift gate just a fraction of an inch (like it's pulling it "more into the gear"). Then when I let off the gas it pops forward again. It's not a big movement, but enough that I notice and it feels weird because my old car didn't do this. Can't remember if it happens when I apply power after cruising or lift-throttle, but is this normal? Or should I start sweating?
Old Oct 7, 2001 | 07:19 AM
MaDMaX024's Avatar
Re: Is the manual shifter supposed to do this??
my shifter does this too, seems to only be in 4th..or at least i only notice it in 4th. i figured if i drive it real hard and it doesnt get any worse, its normal..i havent had anything change yet since i bought the car in july.
also, when you let off the gas does the shifter move "out" of the gear a little? mine does. i dont know what to say except mine does the same thing. maybe matt93se could help us out because i think he just had his tranny rebuilt.....
Old Oct 7, 2001 | 02:27 PM
nardo'89SE's Avatar
it happens in all gears and its normal
Old Oct 7, 2001 | 03:27 PM
flyry110's Avatar
just the mounts flexin.
Old Oct 7, 2001 | 03:33 PM
KLoWnPR109's Avatar
mine does this too, I usually only notice it in 4th and 2nd though
Old Oct 7, 2001 | 03:36 PM
Czar's Avatar
Yeah the shifter is connected to the rear of the transmission, so as the mounts flex through acceleration and deceleration, the shifter will move a bit and this is perfectly normal.
Old Oct 7, 2001 | 06:20 PM
Bman's Avatar
oh good, thanks to all that replied! (exhales)
Old Oct 7, 2001 | 10:37 PM
Brian_TII's Avatar
You guys might want to take your hand off of the shifter while driving around, it's a bad habit that you should avoid. Basically when you rest your hand on the shifter you can put extra pressure on the shift forks and cause increased wear on them. Seriously, my mechanic can tell all about people's driving habits by looking at their trannys....
Just a thought...
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
atriuum
Sep 28, 2015 01:19 PM
