put 225/55/16s on my max /w sprints and stillen kit
Old Oct 17, 2001 | 04:45 PM
ngthing's Avatar
when I turn, they rub every now and then. when i bottom out, i hear the tires rubbing the top of the car.
just an update
also, there is NO way 235s would fit on the car. 225s have about 5cm from the strut base.
Old Oct 17, 2001 | 04:52 PM
jim90gxe's Avatar
Re: put 225/55/16s on my max /w sprints and stillen kit
just an update
What's the offset of your rims? which rims do you have?
Old Oct 17, 2001 | 05:05 PM
ngthing's Avatar
Re: Re: put 225/55/16s on my max /w sprints and stillen kit
stock 4th gen SE rims
Old Oct 17, 2001 | 05:12 PM
Jeff92se's Avatar
I'm needing a caw
I got 235-45-17s on mine. Mr. Rose was running 245-45-17 for a short time. It all depends on the wheel's offset.
Old Oct 17, 2001 | 05:16 PM
ngthing's Avatar
what are stokc SE offsets? and what offset will allow me to run larger tires wihtout rubbing?
Old Oct 18, 2001 | 07:32 AM
maxmizd27's Avatar
just an update
Same size here and mine rub occasionally too. Don't have the bottoming out problem cuz I have Eibach's.
Old Oct 18, 2001 | 12:12 PM
Dirksmoothe's Avatar
intrax
I have the 98 SE wheels as well and they rub sometimes with hard turns, no bottoming out though.
are sprints that cheap? I have the intrax and aside from a slightly stiffer ride then the eibachs, I have had no problems with them.
What about sprints though? are they a relatively good brand?
Old Oct 18, 2001 | 10:14 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i run 225/55's now too...no rubbing here...
Old Oct 18, 2001 | 10:37 PM
flyry110's Avatar
225 55 15's here as well with no rubbing. ST springs.
Old Oct 18, 2001 | 10:44 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i forgot you were running those on your 15's....crazy foo
Old Oct 19, 2001 | 09:27 AM
flyry110's Avatar
i thought that's what you had?
Old Oct 19, 2001 | 09:34 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
nope ...
*cough* mine are 16 *cough*
Old Oct 19, 2001 | 09:46 AM
flyry110's Avatar
what rims do you have? i thought you had the stock SE wheels at the meet. did you get new ones or did i just not notice.
Old Oct 19, 2001 | 11:03 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
hehe i got new ones as of wed. night...pics to come in a week after the meet in NY
Old Oct 19, 2001 | 03:09 PM
Mr. Rose's Avatar
245/45/17 here. Had them under the fender too. HAd several BIG people sit in my car to get it to lower. Fits very snug under the fender. Now I will be doing some serious wrenching in the next month. watch close for updates on project "MAXBRA". Upgrading to a Kumho 235/45/17 next. Less sidewall flex with a 235/45/17. http://home.satx.rr.com/jasonr/wheels.html
Old Oct 20, 2001 | 08:24 AM
flyry110's Avatar
you could go down in profile. that would help more than making them skinnier. go to like a 40 or 35 series.
Old Oct 20, 2001 | 10:58 AM
ngthing's Avatar
that's a bad idea...it throws off your speedo, and will wear your tire faster.
Old Oct 20, 2001 | 01:08 PM
flyry110's Avatar
ok 245/35/17" tires have an overall diameter of 24.7, the stock size on the maxima has a diameter of 25.5. (unfortunately these were different brand tires, but you get the idea. diameter might be different for different brands) your speedo will be off, but it won't be too signifigant. and i would also like to know how a smaller profile will increase tire wear? i'm not flaming, i just don't know. a 35 series profile will be a high performance tire, so the treadwear will probably be softer, but other than that. . . . also, i did see a 245 40. . . that might help a little.
Old Oct 20, 2001 | 01:12 PM
flyry110's Avatar
oh btw, using the same tire 235's are undersized by .3" and the 245's are oversized by .4" so a 245 35" tire being off by .8" is a small price to pay for the width of the tire.
Old Oct 20, 2001 | 02:46 PM
Mr. Rose's Avatar
I use...
http://www.miata.net/garage/tirecalc.html
for tire sizing. I go by a 205/65/15 stock, then I compare the plus size. This website tells me that the 235/45/17 is the closest I can get for an 8" rim.
Old Oct 20, 2001 | 09:16 PM
flyry110's Avatar
hmmmmmm yeah i dunno if a 245 will fit on an 8" rim. . . .certain tires i know will, it just depends.
Old Oct 22, 2001 | 03:32 PM
Mr. Rose's Avatar
245/45/17 is the flush sidewall size for an 8" wide rim. 235/45/17 makes the sidewall roll/curve back tworad the inner of the wheel. The thing we need to remember about calculating the overal height of a tire/wheel combo is the percentage the side wall roll/curves outward or inward. That's why we use a tire size calculator equation, that percentage is built in; rather than converting mm to inches on paper.
Old Oct 23, 2001 | 05:31 AM
maxmizd27's Avatar
The generally accepted rule is to keep the tire height within 1/2" of the stock combination. Any more or less gets into the territory where gearing and speedo's are thrown off. A combination that is .8" off of stock I'd stay away from. My first set of tires was .4" under and my current ones are .1" over.
Cotozic
Jun 28, 2017 08:01 PM
cheftoo
Aug 20, 2015 05:17 AM
Team STILLEN
Aug 10, 2015 04:29 PM
sc10692
Aug 9, 2015 09:37 AM
