Tire question
Old Sep 19, 2007 | 08:26 PM
maxima_man1992's Avatar
Tire question
I was just wonderin if P245/50R17 would fit on a maxima? And has anyone ever removed the black box thing under the gas pedal??
Old Sep 19, 2007 | 08:33 PM
ustfdes's Avatar
- Product of Maxima.org -
i'm not too sure about the tire size....but there is a wheel and tire forum on the .org you can go look at, or you can donate and use the seach function yourself.
about the black box thing, are you talking about the little 'pedal stop' box? or another box?
i don't have a pedal stop, if that helps.
Old Sep 19, 2007 | 08:44 PM
yea i was talkin about eh pedal stop, does it really do anything to the throttle or is it a waist to take it off?
Old Sep 19, 2007 | 08:58 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
iirc the throttle body has a stopper that keeps it from extending past the WOT point... so if anything you're just putting your leg's weight against the throttle cable. i say have someone hold your pedal to the stopper.. then see if the throttle plate has any rotation left in it. if it does have a little more to go, remove the stopper. if the stopper stops it exactly at WOT and you can't turn the TB by hand any further... leave it there. when you stomp it you don't wan to rip the tip off your throttle cable from not having a stopper.
Old Sep 19, 2007 | 09:00 PM
alright sweet thanks ill leave it in
Old Sep 19, 2007 | 09:03 PM
i hope you read the edited version. I totally forgot about the TB having stoppers on both ends (thus perihelion point vs overrotation is not a problem). but the potential vulnerability of the tips of the cable is enough reason for me to leave it in.
Old Sep 19, 2007 | 09:07 PM
ustfdes's Avatar
mine hasn't been on two years, no problems because i don't "STOMP" on it. i do put good pressure on it, but not past the point where i feel the engine is actually properly using the fuel being delivered....i.e.: when you are going 25 in 5th gear and you 'stomp' on it, and all it does is -bog-, the engine isn't properly using the fuel.
use the method caped suggested to find out how much extra cable you have at the stopper point.
Old Sep 20, 2007 | 07:04 AM
Cliff Clavin's Avatar
Way out West
That tire size might fit (depending on your offset) and would increase the diameter of the tire size by over an inch (quite a lot).
That tire size is over 4 percent larger than stock, so your speedometer would be off, too.
There is a tire and wheel section that has a tire calculator.
Old Sep 20, 2007 | 10:09 AM
its a wheels and tire package on ebay but i might just swap out the tires and get some new ones if there is a problem.
Old Sep 20, 2007 | 02:27 PM
haha ironic that i haven't done that myself. maybe i should..
EDIT: just checked... i used a pole to hold the pedal down, and there was NO slack left... at all.
Old Sep 20, 2007 | 03:03 PM
Matt93SE's Avatar
STFU n00b!
235/45/17 is about the ideal 17" size for our cars. 245/50/17 is more like a Mustang or a Charger or something. pretty tall tire. you'd lose some power in the gearing and add a lot of unneeded weight to the drivetrain.
I'd recommend to keep shopping for another set of wheels.
then again if the price is right, you can always buy it for the wheels and have the seller dismount the tires and ship wheels only.
Old Sep 20, 2007 | 09:06 PM
what is the max offset we can have on these cars without rubbing
MR2 T'd
Jul 9, 2021 05:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
videomano
Sep 8, 2015 03:28 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
