Replaced Fuel Pump...
Old Sep 29, 2007 | 01:39 PM
VEvolution's Avatar
I miss my VE
but the hose that attatch to it were a super PITA to get back on, so I damaged one of them to a point where it leaks a bit.
Looking at the FSM, it looks like the other end of the hose can be accessed by just removing the driver side rear wheel. Just wanted to double check..
I would like to drive the car to work tommorrow and most likely fix it there.. Anything I can use for a temporary fix with stuff layin around the house? Duct tape? Thanks a bunch.
Old Sep 29, 2007 | 02:21 PM
AM_BlackMax's Avatar
Fox Body FTW
I just got this problem fixed yesterday by my mechanic. it was a slip-on/slip-off job once he put the car on a lift. The part is about $44 to replace. All he did was take off the rear driver wheel, pull it off(the old hose), and forcefully put the new one on. Now mine had 2 slices, which was causing my gas to leak when i drove and leak when i pumped gas. For a quick fix, i wouldn't recommend duct tape for a period longer then 3 days, even that is too long. the adhesive will wear pretty quick if gas is trying to leak out(i think) so if u have any STRONG/Sturdy like packaging tape, wrap it around the tear until you can get the new hose.
I'm not 100% sure but that's just the advice i'd follow.
Old Sep 30, 2007 | 06:16 AM
VEvolution's Avatar
I miss my VE
OOoo great.. Thanks for the heads up
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
