need input (no pun intended)
Old Oct 1, 2007 | 05:48 PM
sublunary's Avatar
my batt. was totally dead yesterday and when i tried to jump it i heard a sound from the abs actuator. (the dash light had been coming on and off for a few weeks) i couldn't get the car to jump start. i found a thread that mentioned the abs actuator trying to pump after the car is turned off and killing the battery so i disconnected the abs and tried to jump start again. this time it did start but turned off right after taking off the jumper cables. i tired again and checked voltage at battery after restarting and instead of 14v i was getting 12v. i took off the cables and the car ran for 30 sec. and cut off again. so i replaced the alternator today and got the battery recharged and just tried to start the car and got no dash lights but a very faint battery light and no start. so i checked the fuses and found the main 100A fuse next the the positive terminal on the battery was blown. what the hell? need some advice.
Old Oct 1, 2007 | 05:55 PM
Greeny's Avatar
¯\(°_o)/¯
Chances are you blew the big fuse when you jump started the car,or your faulty alternator blew the fuse<--(this has happened to me before so just replace the fusible link and you should be fine.
Oh btw,i recommend you get it at the dealership,they are about $8 iirc.
Old Oct 1, 2007 | 06:03 PM
sublunary's Avatar
the fuse is different than the ones around it in terms of how it is removed. i couldn't find how it is hooked in. nothing it press or pry out. do you just yank it? i pulled really hard and it didn't move
Old Oct 1, 2007 | 06:09 PM
Greeny's Avatar
¯\(°_o)/¯
You have to remove the bottom part of the fusebox,then remove a 10mm screw to get the old fusible link out..
I think i snapped some pics of this procedure,but they are on my other pc..I'll check.
Old Oct 1, 2007 | 06:19 PM
sublunary's Avatar
dont bother that is more than enough help. isn't it very unusual to blow such a large fuse? i was worried that i have a short or something with the new alt. so i guess i should get two fuses in case i blow the next one.
by the way i have been to crossvul (as they way down there) i went to mtsu and we played someone in soccer there one time
James92SE
142
Jan 2, 2024 09:23 AM
gigabyte
Jan 6, 2017 06:05 PM
