Knock Sensor Question
Old Oct 19, 2001 | 02:51 PM
GreenMaxVE's Avatar
First time poster. I have been noticing a loss of power and fuel economy when my car gets up to temp. I ran diagnostics and found a bad knock sensor. I was wondering if there is an easy fix for this (like grounding the VTC's). Can I ground out the connector? Or maybe another easy fix? I really don't feel like taking the intake manifold off just to change one little sensor!
P.S. I cleaned the coolant temp connector, but that didn't help.
Old Oct 19, 2001 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
No easy fix. But it could be the connector or wiring harness. Check those also before digging into there to replace the knock sensor.
Old Oct 19, 2001 | 03:04 PM
GreenMaxVE's Avatar
I checked the harness connector with an ohmmeter. Chilton's said I should have a continuous circuit between pin A and ground. There wasn't continuity. So I think it's a bad sensor.
Old Oct 19, 2001 | 03:19 PM
Jeff92se's Avatar
I'm needing a caw
Well if you want to replace the sensor, it's really not that hard to take off the intake manifold. It's a little time consuming but not too technical.
You'll need the correct sized allen/socket to get the manifold allen bolts off. It would be a good time to clean out the TB also. You will need a new in. manifold gasket and a new TB gasket also. Might be time to check/replace any fuel injector hoses that are getting old/brittle/leaky when cold.
Old Nov 17, 2001 | 05:15 PM
Riot^'s Avatar
Will a knock sencor reduce the power of a car?
I noted that my car doesn't pull as well as it should. I did an ECU check and got the knock sencor code. I have been using low octane, and I hear that plays a role on the sencor, but that much loss of power?
So in any case, will it make me lose power? and how do I diagnose the wiring harness and the connectors?
Old Nov 17, 2001 | 06:52 PM
GreenMaxVE's Avatar
Re: ...
Yes, I think it does. My knock sensor will test out fine some days and be bad on others. When it is working I notice that my car pulls much better in the 2K-3K range. To test the connector, find the wire that comes from underneath the intake manifold and follow it to the connector. The connector should have 2 pins. Hook up an ohmmeter between the neg terminal of the battery and the pin closest to the radiator. You should get a continuous circuit. If not, probe the wire below the connector. No continuity will mean a bad sensor.
Hope this helps!
Old Nov 18, 2001 | 09:51 PM
Riot^'s Avatar
can't find it.
Can someone tell me exactly where that sensor is?
I have been looking all over for it, and either I am blind or I can't find it! I see the Throttle Positioning Sensor in that area where I think it should be, and that is it!
It would help if someone had a picure of it!
Thank you.
mvm062
Nov 30, 2020 09:00 AM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
