Firewall
Old Oct 20, 2001 | 06:08 PM
Maxpwer's Avatar
No turbo, no care!
Firewall
Im trying to run some large wires from the battery, though the firewall for a stero, but I cant find a hole. Is there any avalable holes, and if so where are there? If not, can I drill a hole, and where is a good location to drill a hole?
Old Oct 20, 2001 | 06:45 PM
Matt93SE's Avatar
STFU n00b!
the best place to run it is to pull off the left side fender liner (on the inside of the wheel well), then you'll see the factory wiring harness and grommets.
if needed, you can drill a hole there too. pics on my website..
www.ee.utulsa.edu/~mblehm/pics/car/alarm
look at the first few pics.
Old Oct 21, 2001 | 07:44 AM
Tick Tock's Avatar
Matt's idea and pics are great. However, it depends upon where you want the wire to go. If it's just from the engine compartment to the under dash area, I have found it's best to drill a hole right by the steering column. You first can look inside the engine compartment-find a position by the steering column that's open - that is, where you won't drill into something else and is clear to run wire.
Then remember this spot - and drill from under the dash in the same position from the steering column. I then put on a thin coating of silicone sealer on the hole and put the rubber grommet in-place. Then run your wire and seal on both sides with silicone sealant. I've used this technique for years and have never had any problems, rust, etc.
Old Oct 21, 2001 | 10:29 AM
Kraus91SE's Avatar
I drilled this hole almost 4 years ago, it was the best spot I found.
Old Oct 21, 2001 | 10:49 AM
Brandon90gxe's Avatar
haha nice pics matt.. where are your neons?
Old Oct 21, 2001 | 08:09 PM
Matt93SE's Avatar
STFU n00b!
right here..
http://www.ee.utulsa.edu/~mblehm/pic...1/MVC-008F.JPG
Old Oct 22, 2001 | 06:45 AM
DaBoxSE's Avatar
right here..
Hmm...link doesnt seem to work for me
Old Oct 22, 2001 | 07:11 AM
Matt93SE's Avatar
STFU n00b!
Came right up for me.. maybe the server was down when you tried it.. not uncommon on our lame school network.
fastcarny
Oct 12, 2015 07:06 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
