Axle Rusted stuck
Old Oct 28, 2007 | 05:37 PM
Maximahappy22's Avatar
Axle Rusted stuck
Im doing my clutch and my pass side axle is rusted stuck to the support bracket for the axle, anyone have any ideas about how to get it out?
Thanks,
Alex
Old Oct 28, 2007 | 06:13 PM
internetautomar's Avatar
mod or sell?
the red wrench
Old Oct 28, 2007 | 06:37 PM
K well i got the axle bracket to rotate by hitting it with a hammer, but still no luck on getting it out. Is there a specific place you guys recommend to pry or pull from?
Old Oct 28, 2007 | 06:48 PM
maxima-junky's Avatar
I usually cut them rusty bolts out with a hack saw or a grinder. Then take a hammer and screw driver and knock it out.
Old Oct 28, 2007 | 06:59 PM
Greeny's Avatar
¯\(°_o)/¯
This is how i removed both my maxima passenger side axles..
Old Oct 28, 2007 | 07:20 PM
ok but where are you hitting from? i just dont want to break anything
Old Oct 28, 2007 | 07:31 PM
Greeny's Avatar
¯\(°_o)/¯
You have to remove the d-side axle,then take a long instrument of some type(large screw driver/end of a breaker bar/etc.) Hit the end of the passenger side axle through the hole on the d-side axle side of the transmission..
http://www.autozone.com/images/cds/g...3d801f558d.gif
Old Oct 28, 2007 | 07:35 PM
gerryv's Avatar
hot wrench or
you can torch it or there is this suff called kroil it can be a bit hard to find but this stuff is like liquid gold i have take off exhaust bolts and studs with the stuff even when they looked like they would break . this is the web site for it.
www.kanolabs.com
Old Oct 28, 2007 | 07:38 PM
Greeny's Avatar
¯\(°_o)/¯
+1 to above about lubing up the support housing area.but i recommend pb blaster for the job.
Old Oct 28, 2007 | 07:50 PM
gerryv's Avatar
the PB will work
it is alot more availble everywhere than the Kroil
Old Oct 28, 2007 | 08:08 PM
Thanks for the help, GOT THAT B*TCH OUT!!!!!!
Old Oct 29, 2007 | 07:17 AM
James92SE's Avatar
2 VE's are better than one!
Haha, nice. I remember those days. My car is from Pennsylvania and is rusty as **** underneath. I swear it took me 3 days of constant pounding and prodding to get the original passenger side axle out. I never wanted to give up on a car so badly and just throw it down a cliff as I did then.
Old Oct 29, 2007 | 10:36 AM
traxtar944's Avatar
Would be lost w/out the org
Tis' true. It took me a LONG time to get that axle out. I had to hit that thing COUNTLESS times to get it out. Now make sure you take a wire-brush to it, and never-seize that inside surface before you install the passenger side axle again. Not that you'd ever have to get in there again...but just in case, you don't want to go through an ordeal like that again.
Old Oct 29, 2007 | 07:41 PM
Thanks for the advice, will do...
Old Oct 30, 2007 | 06:59 AM
blackandwhite's Avatar
To them I'm like an idol
Thanks,
Alex
http://forums.maxima.org/showthread....ight=passenger
Old Oct 30, 2007 | 07:21 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by blackandwhite
If you would read the whole thread,he already removed the axle 2 days ago.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
