repair the door lock actuator
Old Nov 11, 2007 | 12:11 AM
jguo2002's Avatar
The door lock nut on my 89 max can not move with other nuts when I open or lock the driver side door. It should move, but it did not for a while. I had planed to buy a new acturator, but it needed 30 bucks or so with shipment on the ebay. So I just removed the acturator and fixed it. Fortunately, the small motor inside the actuator works well, just the sprocket inside the actuator was overturned and blocked because some of the teeth of the sprocket bald. Following are the steps and pics:
1. disassemble the actuator. remove those gears until the o-shape fastening ring appear(pic1-pic6).
2. remove the o-shape fastening ring(pic7). check the teeth.
3. sticking the o-shape fastening ring with the base sprocket with glue.
4. install all parts. use the acturator after 1 hour for the glue drys.
Old Nov 11, 2007 | 12:17 AM
jguo2002's Avatar
other pics
Old Nov 11, 2007 | 12:59 AM
ColombianMax's Avatar
Meh I was gonna do the same but I can get em so cheap that I dont even bother...
Old Nov 12, 2007 | 12:02 AM
idtag's Avatar
I'll keep that one on file. I'd try to fix my own too, just to see if it could be done.
REDinLV
Aug 15, 2024 12:30 AM
mkaresh
Mar 12, 2018 06:48 PM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
