YAY!..I'm keeping Blackmax :-)
Old Nov 14, 2007 | 04:24 PM
  #41
AM_BlackMax's Avatar
Fox Body FTW
makes...sense now...just ...wasnt explained above...
yeah...sorry about that
I DECIDED TO KEEP THE MAX!
until i see a lot more beauteeful cars F/S for a reasonable price
Old Nov 14, 2007 | 04:36 PM
  #42
ColombianMax's Avatar
Uh no, I decided for you to keep the Maxima and thats FINAL
see? http://forums.maxima.org/showpost.ph...3&postcount=29
Old Nov 15, 2007 | 07:29 PM
  #43
Fox Body FTW
"okay"
well now i uploaded the video where you hear an abnormal sound when i shift gears. And when i shift [as of now] it's like a jolt as it makes it's transition into first.
http://www.youtube.com/watch?v=v23a5oXWmxI
Old Nov 15, 2007 | 07:34 PM
  #44
Greeny's Avatar
¯\(°_o)/¯
"okay"
Sounds like a broken motor/transmission mount,or maybe loose/broken exhaust parts...Most likely a mount..
Old Nov 15, 2007 | 07:35 PM
  #45
"okay"
Sounds like someone needs mounts. Get a second person to step on the brakes while the the car is on Reverse and Drive as you observe whether engine moves or not when the other person gives it some gas. pardon the run on sentence. no time to edit!
damn you wayne, beat me to it
Old Nov 15, 2007 | 07:37 PM
  #46
Greeny's Avatar
¯\(°_o)/¯
Old Nov 15, 2007 | 07:40 PM
  #47
Fox Body FTW
so should i get this
for $43 and that's it? or what all do i need?
because the site i went too is showing "different" mounts w/ varied prices
http://www.innerauto.com/store/?N=16...=true&swr=true
Old Nov 15, 2007 | 07:59 PM
  #48
internetautomar's Avatar
mod or sell?
you won't know until you look
Old Nov 15, 2007 | 08:04 PM
  #49
probably yes but you'll eventually need 3 more
Old Nov 15, 2007 | 08:06 PM
  #50
Fox Body FTW
look where? how do i know what I'm looking for if i don't know what to look for..
Old Nov 15, 2007 | 08:19 PM
  #51
92gxe/cg2's Avatar
i believe there are 4 mounts, one trans and 3 engine. My gxe makes a similar sound to urs and i know its the mounts. Soon enough il get them. If you only get one mount, the new, strong mount will effectively destroy the old weaker mounts. So you will need all four in time or u could just get them all at once. I was thinking of just gettin one or two but john steered my in the right direction once again....
Old Nov 15, 2007 | 08:23 PM
  #52
CapedCadaver's Avatar
Call me Wookiee Goldberg
i am such a victim. i have a poly front mount with 3 other worn OEM mounts. front tranny mount is wholesale slaughtered.
Old Nov 15, 2007 | 08:52 PM
  #53
mikekantor's Avatar
What to look for:
Old Nov 16, 2007 | 06:27 AM
  #54
mod or sell?
as 92 GXE said that he learned from john, that john learned from me.
do all the mounts at once. whichever mount you don't replace will become the weakest link and will fail in a short time after you've replaced the others.
PM me and I'll see what I can do for you on a set of mounts that aren't junk.
Old Nov 16, 2007 | 07:26 AM
  #55
Pfff I figured it out when you pointed it out
Old Nov 16, 2007 | 08:14 AM
  #56
92gxe/cg2's Avatar
O and if you ahve any other sets of mounts that "arent junk" feel free to let me know, otherwise il have to save up a couple weeks and pay ur work a visit...
Old Nov 16, 2007 | 09:39 AM
  #57
mod or sell?
I thought I quoted you on the mounts already
Old Nov 21, 2007 | 06:02 PM
  #58
Fox Body FTW
I just found out what the rattling noise was.....it's my hood..had nothing to do w/ the tranny
and also, the raw gas thing turned out not to be raw gas..just poor condensation....i can't tell the differen't TBH
Old Nov 21, 2007 | 06:06 PM
  #59
mod or sell?
Old Nov 21, 2007 | 06:18 PM
  #60
92gxe/cg2's Avatar
Oh thats right, i think i remember it was like 220 ish....
They might have to get put off for a little while, need the money for other things right now.... i will be in the process of doing a part out soon (as if there arent enough already) so maybe i can get something outta that.
Old Nov 21, 2007 | 06:38 PM
  #61
mikekantor's Avatar
...and also, the raw gas thing turned out not to be raw gas..just poor condensation....i can't tell the differen't TBH
Hate to say I told ya so.
I emailed some people about a job, cross your fingers.
Old Nov 21, 2007 | 07:27 PM
  #62
Fox Body FTW
lol, hey i'm new to this stuff so i'm learning as i go
sweet dude! thanks
Old Nov 22, 2007 | 12:11 AM
  #63
teenagers I tell ya....
Old Nov 24, 2007 | 11:49 PM
  #64
Fox Body FTW
hey what r u tryna say
anyways, is "How to do a tune-up/What you'll need for tune-up" in the FSM? if not, What parts will i need to give my car a tune up? A little write up would be nice but i'll take what i can get
Same goes for Fuel Injectors..Thanks for any responses!
[note: this'll be my first time doing it so i'll try my best to know most of what ur talking about prior to you responding]
Old Nov 25, 2007 | 02:47 AM
  #65
Tune up:
1. Distributor Cap (Preferably OEM)
2. Distributor Rotor (Preferably OEM)
3. Sparkplug Wires/Ignition Cables (same thing)
4. 6 sparkplugs (preferably OEM/NGK)
5. Air Filter
6. Fuel Filter
7. PCV Valve
8. Di-Electric Grease for sparkplug wires
9. Injector cleaner
10. Oil +filter+crush washers if you wanna go all the way.
11. Small hose clamps, Fuel injection clamps are a plus.
Thats just to get you started, get those parts and then we'll go from there. Expect to pay $75-$100 bucks for everything
Tools needed:
1. 1/4 and/or 3/8 Rachet
2. 8mm socket for cap/rotor removal (you can use phillips too)
3. Channel locks/pliers to remove hose off PCV Valve
4. 13/16 sparkplug socket with rubber inside to hold sparkplug in place.
5. phillips screw driver/pliers to remove fuel filter
6.oil filter wrench to remove oil filter (duh)
7. 14mm socket for oil drain plug
If I missed anything.... I guess you'll find out and let me know :P
Old Nov 25, 2007 | 09:04 AM
  #66
Pearl93VE's Avatar
I can has?
Tune up:
5. Air Filter
6. Fuel Filter
7. PCV Valve
9. Injector cleaner
Tools needed:
Looks good except he has the VE. Pull out your coils (Held in by one screw for the front 3 cylinders, 2 for the rear) And check for any cracks in the front one's. If you don't find cracks, I would wait until you finish all other inexpensive tune up items to see if it helps your car, before replacing these. So in Johns help above, just ignore the distributor, rotor, and spark plug ignition wires.
Old Nov 25, 2007 | 12:08 PM
  #67
Ah ok, I thought he was all VG but I thought wrong
Old Nov 25, 2007 | 02:30 PM
  #68
Fox Body FTW
No VG under here
Old Nov 25, 2007 | 03:08 PM
  #69
Pearl93VE's Avatar
I can has?
hot damn, my VE purrs compared to most of the video's I see....
Old Nov 25, 2007 | 06:47 PM
  #70
Pff my VG sounds sexier so you take that lil face back!!! BACK~!!!!!! lol
Old Dec 10, 2007 | 03:29 PM
  #71
Fox Body FTW
ok well i had a little mishap on weds. of last week..long story short, someone cut me off, i avoided the crash by trying to go around (on the grass; and it was snowing) and i lost control [it kept sliding to the right], hit several dips and came to a complete stop/the car cut off about 3-5 feet from an electricity pole. it turned back on but the idle was very rough...much worse then before. (i thought it was the tranny) but come to find out (cuz it's been in the shop since saturday) that 3 fuel injectors are done/getting replaced and the grand total of that is $700
http://videos.streetfire.net/video/5...fd017e48e5.htm
my tires marks imprinted in the snow 2 days after the incident.
Old Dec 11, 2007 | 01:19 AM
  #72
Hey did my post from yesterday get deleted? or did I not post? I could've sworn I did... I'm going crazy
Old Dec 11, 2007 | 01:23 AM
  #73
elusivemax93's Avatar
it prolly did as have some of my post been deleted lately as well. o well forums becoming far to censored now. blah hum bug
Old Dec 12, 2007 | 08:53 AM
  #74
Fox Body FTW
i got my car back from the shop and the power felt weak/hesistating between no throttle and 2000rpms then the new fuel injecters kicked in. i stopped to get some gas and when i started it back up, it turned over but cut right back off. I went to start it back up and it turned over fine. It did the same this morning. then when i got to school (30 minutes later) smoke was coming out my exhaust and it smelt like unburnt fuel (serious this time) and the idle dropped again..then i went to pick up my friend came back, she even said the smell was awful. Then i let the car sit for about 3 minutes tried to crank it up and it wouldn't start. tried it again, same thing. tried it a third time with full throttle and it BARELY started. as i was cranking it before with no throttle (automatic) smoke was pouring out the exhaust. My friend said it might be a blown head gasket...if that's the case...there goes that $750 down the drain...
Old Dec 12, 2007 | 08:59 AM
  #75
mod or sell?
sounds like an o'ring got ripped while getting the injectors installed. take it back to whomever installed them and let them fix it.
Old Dec 12, 2007 | 09:01 AM
  #76
mikekantor's Avatar
What color was the smoke?
Have you looked at your oil or coolant to see if they are contaminated?
A wild guess: shop dropped something into cylinder while changing injectors.
Old Dec 12, 2007 | 04:02 PM
  #77
Fox Body FTW
yeah i did this afternoon.
the color of the smoke was like a light blue. it smelt like gas to me inside and out the cabin...especially with the heat on.
the mechanic said one of the FIs is getting too much gas (which explains how i filled up last night and am below 3/4 in less then 50 miles) so he's fixing it now and i should have it back tomorrow hopefully..
Old Dec 12, 2007 | 06:02 PM
  #78
blue smoke is oil burning IIRC
Old Dec 12, 2007 | 08:13 PM
  #79
Fox Body FTW
it was a mixture of both [blue & white smoke]. Yeah my grandmother told me that (the burning oil thing)
On the start up it was white and when it's just idle white semi-thick smoke with a gas-like smell and when I'm driving it was blue and would smell like gas in the cabin whilst driving with the heat on..so i had to turn on the A/C..
Old Dec 12, 2007 | 08:35 PM
  #80
augiedog964's Avatar
I would hate to butt in, but this thread has been random anyway, where were you able to get such nice wheels and tires for so little and did you need to modify anything, spacers etc for them. I want 97-99 wheels, but I cant find them anywhere at a decent price. Good luck with your car, I had to get all my injectors replaced, but it has been smooth ever since, way worth it to keep the car
