Heater experts, drop some knowledge
Old Nov 16, 2007 | 07:52 AM
mikekantor's Avatar
At the moment, my heater only works when the car is moving > 35mph. As soon as I cross that barrier, I get heat immediately. If I get below it, the heat slowly fades away, speed up again and its back.
I first noticed this two weeks ago, and thought that maybe I did something wrong when I put the motor back in. A week go I took some time to check around, looked over hoses, everything looked good. Took it out for a test drive and the heater was working normally, so I thought "great! I fixed it!"
This week I drove a few times, and its back to doing the 35mph thing.
Old Nov 16, 2007 | 08:28 AM
Greeny's Avatar
¯\(°_o)/¯
Are you sure all the vacuum lines at the water **** valve are hooked up correctly?
Old Nov 16, 2007 | 08:44 AM
mikekantor's Avatar
I thought I was sure when it worked right, but that only lasted a day or two.
Old Nov 16, 2007 | 09:07 AM
Greeny's Avatar
¯\(°_o)/¯
Old Nov 16, 2007 | 09:11 AM
Darkwing48's Avatar
A while ago, on the threads, someone talked about replacing a resistor will solve this problem. It's in the archives now. Someone could dig up the thread. I have the same issue too.
Old Nov 16, 2007 | 09:17 AM
Greeny's Avatar
¯\(°_o)/¯
I think you are referring to the blower motor resistor?
This issue pertains to the fans control only working on 1-2-3 but not high (4).
Old Nov 16, 2007 | 10:07 AM
mikekantor's Avatar
Judging by that pic I did get some things wrong. Looks like I threw away one old hose and forgot to replace it during assembly.
I have extras so I'll cut and replace it once I'm home. Right now mine is hooked up in such a way that it skips that middle plastic part to which both small hoses connect.
Problem solved, thanks!
PS: My blower motor and resistor are working fine, thanks anyway darkwing.
litch
123
Jan 4, 2024 07:01 PM
howardis
Dec 11, 2019 06:10 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
maxima-junky
Oct 7, 2015 06:13 PM
