help-remove the crankshaft pulley on 89 maxima
Old Nov 16, 2007 | 07:40 PM
jguo2002's Avatar
I have to remove the crankshaft pulley to change timing belt. However, it is hard to remove it. I just bought a electronical impact wrench which can produce 345 ft lbs power. But what size is the crankshaft pulley bolt on 89 maxima? I tried 1 1/16 in socket, but it loosed when the impact wrench was turning? The 1 in socket is a lit small. There is not a socket size between 1 and 1 1/16 in in Kragen. I tried 26 mm socket also, and it is a lit small. But the 27 mm seems bigger than the 1 1/16 in one. Is there any special socket or tool for the bolt?
Old Nov 16, 2007 | 09:22 PM
oldngivout's Avatar
Willing to learn
It's 27mm. You should be using a 6 point socket if possible also.
Old Nov 19, 2007 | 03:00 PM
helps
my bolt was so screwed up from rocks? that i had to get a hammer and tap the socket over it.
Old Nov 20, 2007 | 10:31 AM
TWINTRBO's Avatar
Just brace a breaker bar on something sturdy like the firewall and hit the starter for a second, it works wonders! Of course an impact gun is better, but not cheaper! Of course make sure its a secure setup, dont need flying tools in your wheelwell.
Old Nov 20, 2007 | 01:06 PM
goon9's Avatar
Wurd... I jammed a breaker bar on the ground and cranked it
Old Nov 20, 2007 | 02:47 PM
gapboi210's Avatar
On my last 3rd gen the pulley was frozen on. Ended up having to use an air chisel and take it off in chunks.
Old Nov 20, 2007 | 03:04 PM
mikekantor's Avatar
Did you get a pulley puller this time? AZ rented me one, but I ended up not needing it... all the oil leaks made it slide off effortlessly.
Old Nov 21, 2007 | 07:35 PM
jguo2002's Avatar
Thanks guys! I ended up with renting a air compressor from Hertz Tools Rental and buying air impact wrench. I think it will be helpful if someone else need it. I can lend you it.
Old Nov 21, 2007 | 08:14 PM
mrkanda's Avatar
Taking my Maxima to the Max!
A couple weeks ago I got a whole air compressor kit with impact gun, air ratchet, air guage/filler, air blower nozzle, 4 impact sockets, a finish nailer, and a 25 ft. air hose for only $150 from Home Depot. It was the floor model . I'm sure it will come in handy for projects like this once I dig in to all the stuff I have to fix. I also changed my Timing Belt back in '02 when I first got the car. I didn't know about the .org then, so I got creative and rigged up a tourniquet belt around the pulley that had a wet piece of cloth inside it to grip and was tied on the other end to a bar across the top of the engine. This made the pulley hold still until I could get it loose with the breaker bar. I'm sure one of the other suggestions given here would work much better.
Good luck!
Old Nov 21, 2007 | 09:47 PM
Maximahappy22's Avatar
Put the car in 1st gear, have someone step on the breaks and hit it with your impact gun, i just did this on my VE and it worked fine.
02PearlSE
Oct 7, 2015 02:12 AM
schmellyfart
Sep 25, 2015 04:47 PM
kenc15
Sep 25, 2015 06:38 AM
