cheap superchargerd
Old Nov 19, 2007 | 10:35 PM
helps
cheap superchargerd
so i come across some electric superchargers. they claim to put out 2-3 psi, well so out of boredness i was like what the hell. i bought 3 of them. hooked one up, it put out about 3 psi, i was like wow. so i got this stupid idea to hook all 3 of them up, given there was no room we took off the hood and after many hours we got all 3 wired and hooked up, had to add an extra battery. well it puts out 6-7 psi when i measured it at idle( i assume it will go down as you give it throttle) but after driving it it did a significant increase in hp. i might actually leave them in.
Old Nov 19, 2007 | 10:49 PM
helps
thinking about this it was a stupid idea, and they probably wont last the morning but whatever kept me happy for 30 seconds or so
Old Nov 19, 2007 | 11:11 PM
Hectic's Avatar
What changed in 14 minutes?
Old Nov 19, 2007 | 11:12 PM
helps
there starting to clack and im about to remove them b4 the fans break into my motor :/
Old Nov 19, 2007 | 11:20 PM
ustfdes's Avatar
- Product of Maxima.org -
the electric supercharger was a good idea, i've even considered the possibilities before i learned of the existing technology....but it is also an idea that is hard to efficiently put into motion.
they require more batteries, and don't really put out enough pressure to be worth the money spent, and the added weight.
i just happened to have read an article abotu the first guy to try it back in the 60s/70s and was pretty interesting, yet dissappointing. i do have better ideas about how to make it function using less energy, and producing more pressure, but that is for another time
Old Nov 19, 2007 | 11:43 PM
Pearl93VE's Avatar
I can has?
Impending criticism...
Old Nov 20, 2007 | 12:56 AM
LvR's Avatar
LvR
Well - I stay at 1375m above sea-level, and would simply love to have the about 1.5lb pressure drop because of hight negated and my car perform as when at sea level, so 3lb would be nice if it can be made to be reliable.
Guess the KS will be a busy fellow with such an installation, because the problem is you need timing/fuel etc etc adjusted accordingly and I don't know where you will cheaply find higher octane fuel to run on permanently.
Old Nov 20, 2007 | 01:04 AM
helps
that and the electric supercharger is only supposed to run when needed not full time.
Old Nov 20, 2007 | 08:50 AM
Maxteca's Avatar
Could you put it on a switch so you can turn it on when you need it?
Old Nov 20, 2007 | 10:13 AM
Darkwing48's Avatar
Like KITTs Boost (Knight Rider for those born in the 90s)
How much did it cost you?
Old Nov 20, 2007 | 10:32 AM
internetautomar's Avatar
mod or sell?
KITT had Turbo Boost.
Old Nov 20, 2007 | 12:25 PM
'90_Maxima's Avatar
Not to mention "jump" capabilities.
I bet that light that made the swooshing noise made it faster, too.
Old Nov 20, 2007 | 12:34 PM
bigpulve+'s Avatar
Leaf Blower...
Old Nov 20, 2007 | 01:02 PM
helps
it comes with a switch yes.
Old Nov 20, 2007 | 01:03 PM
helps
Originally Posted by mazzivart
Leaf Blower...
i have actually tried this, its rediculasly loud and i didnt even try to drive it with it on.
Old Nov 20, 2007 | 01:17 PM
bigpulve+'s Avatar
Old Nov 20, 2007 | 02:17 PM
92gxe/cg2's Avatar
lol, nothing wrong with knight rider. not the greatest special effects but for its time good( altho u could sometimes see the drivers arms and hands when KITT was driving himself, etc.). that is one sweet ride.
Old Nov 20, 2007 | 02:26 PM
mikekantor's Avatar
just sayin'
Old Nov 20, 2007 | 02:27 PM
helps
moral of the story, dont do it. pics or not its a stupid idea.
Old Nov 20, 2007 | 02:41 PM
mikekantor's Avatar
How did you measure the pressure produced? Claimed psi * N s/c?
Old Nov 20, 2007 | 04:36 PM
helps
boost meter
Old Nov 20, 2007 | 07:35 PM
xx-Marshall-xx's Avatar
kthxbye2u
you need to start posting videos of this stuff dude...
Old Nov 20, 2007 | 07:43 PM
ustfdes's Avatar
stupid idea to buy one of those cheap electric stuperchargers, yes. just as stupid as buying one of those little "RACING CHIP! ADDS HP!" pieces of junk.
to make an efficient electric supercharger, you're gonna have to basically build one yourself to get it right.....aftre plenty of research on previous patent downfalls and whatnot.
i think electric is the way to go on a supercharger, because you're not actually 'robbing' power from the engine, to make power.....like a supercharger adding drag, and a turbocharger adding backpressure in the exhaust system. while an electric s/c is still not 'free' power, persay, it is still free-er than conventional chargers.
Old Nov 20, 2007 | 07:50 PM
ustfdes's Avatar
Old Nov 20, 2007 | 07:54 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well there is significant loss of energy to heat even with electronics. Like the bearings on the alternator, and the alternator belt, just to name a few. I would like to see someone run a leaf blower tho.. but I don't know how many watts those use. I know that it would take a heft of juice though.
Old Nov 20, 2007 | 08:08 PM
ustfdes's Avatar
caped....leaf blower......gas powered, note the 'noisy' part. x;
my dad put a leafblower on his charger back in the day just to play around, and said it worked good, but wasnt practical ;x
and abotu the loss of heat to energy....heatsinks and more cooling methods to the dc motors on the s/c and alternator if need be.
if you're cooling the dc motor for the s/c, then you just need to remote mount the motor iself, in a cooler location with more airflow, and then run the prop shaft to where it needs to be.
Old Nov 20, 2007 | 08:13 PM
goon9's Avatar
Best mod yet and no one rip me off.
1. Crank AC on high
2. Route ducts into INTAKE!
COLD FORCED AIR! The blowe in your airbox is greater and COLDER then the ebaycharger!
Old Nov 20, 2007 | 08:20 PM
VLmax's Avatar
thanks for experimenting the electric supercharge. I was wondering how bad the electric supercharge was, since it was cheap in ebay.
Old Nov 20, 2007 | 09:34 PM
helps
maybe i will start posting videos of the stupid stuff i attempt, please note i have 2 91 maximas. one is turbo and the other is something i just screw around in/with.
Old Nov 20, 2007 | 10:43 PM
hoyshnin's Avatar
Baby's on the Half Tip!
Now here's a cool idea...
Anyone remember this idea that Ford came up with?
"With the SuperCooler system, the vehicle’s air conditioning system is used to chill a small storage tank of coolant to about 30 degrees Fahrenheit.
On demand, the SuperCooler system switches the intercooler flow from its normal circulation and dumps the chilled coolant into the engine’s intercooler. In turn, the intercooler dissipates up to 20 percent more heat from the charge air – resulting in a denser air charge.
As a result of this cool technology, the SVT Lighting concept can give its driver as much as 50 transient horsepower for short bursts of 30-45 seconds and regenerate within 2 minutes under normal driving conditions. While its effect is similar to that of an aftermarket nitrous oxide system, the SuperCooler is completely self-contained, environmentally friendly and regenerative."
Here's the link, I thought it was so cool when I first heard about it.
http://www.maximum-cars.com/Cars/Car.php?carnumber=418
Sorry if this is a repost.
Old Nov 21, 2007 | 02:22 AM
Greeny's Avatar
¯\(°_o)/¯
Pics or
Old Nov 21, 2007 | 06:03 AM
Matt93SE's Avatar
STFU n00b!
motion to ban this idjit the next time he posts something stupid like this....
Old Nov 21, 2007 | 06:32 AM
hoyshnin's Avatar
i thought it was interesting, at least entertaining
Old Nov 21, 2007 | 06:38 AM
Matt93SE's Avatar
STFU n00b!
stupid ricers and electric superchargers have been around for years.
you can only see this **** so many times.........
Old Nov 21, 2007 | 10:18 AM
helps
if you dont want to see it, dont look.
Old Nov 21, 2007 | 01:25 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by MyGreenMax94
Pics or
Are you going to post pics of your turbo setup?
Or is it just another hair dryer..
Old Nov 21, 2007 | 01:53 PM
ustfdes's Avatar
lol. i guess you didn't read my type, matt. stupid electric superchargers are so far the best way to create free boost. and if done properly, by yourself, would be excellent.
i'm not siding with helps, as he's the one who bought the ebaycharger. probably tried the "HP RACING CHIP!!!" too. ;x.....but i am siding with the theory of electric superchargers for practical application, not just ricer fcukwads.
Old Nov 21, 2007 | 04:37 PM
helps
why would i post pics of my turbo setup, this thread has nothing to do with it.
Old Nov 21, 2007 | 04:41 PM
Greeny's Avatar
¯\(°_o)/¯
This thread is nothing but a waste of bandwidth any way,so you might as well save it buy posting pictures of your turbo'd maxima
Or I will start you another thread specifically for your turbo pics..
Or i can edit the title of this thread so it includes turbo pics..
C'mon dude...post um up..
Old Nov 21, 2007 | 04:51 PM
Darkwing48's Avatar
He's Calling you out!!!
You going to take that?
Or post some pics?
By the way, is there a racing chip upgrade for VG Max? Just a simple Yes No. Don't expand on it. Meantime, I'll Google
