Painting Brake Callipers
Old Oct 24, 2001 | 05:46 AM
krazyd's Avatar
I know that this really isn't a big MOD to your Max, but i'm getting rims and I want to do mine. Does the painting have any side affects on the performance of your brakes? What types of paint do you suggest I use, and where could I buy them from? Oh yeah, as you can see I drive a white max, do you think that blue callipers would look good? I need some real good instructions and advice to follow, so any comments are appreciated - thanks!
Old Oct 24, 2001 | 06:31 AM
«§»Craig B«§»'s Avatar
Re: Painting Brake Callipers
searh the forums, there are lots of posts about this every week
unless you do it wrong, there should be no effect on your braking. You just paint the outside of the caliper and tape everything else off (rotors, pads, brake lines, etc)
www.fobart.net/ryan/maxima/calipers.html has some stuff on it
there are a few other how-tos for the maxima about this somewhere too that you will find with search
also, try google.com and look up "paint brake calipers" or something like that and you'll find TONS of pics and info; not necessarily for the max, but it's just about the same for every car
use high temp engine paint from any auto parts store; it'll cost you about $5 or so
I did mine silver not too long ago and they look pretty nice
Old Oct 24, 2001 | 09:09 AM
krazyd's Avatar
THANKS!
Google.com had a ****load of useful 'painting techniques'. Do I need to use the metal brushes to clean the brakes though and paint primer?
Old Oct 24, 2001 | 09:54 AM
Matt93SE's Avatar
STFU n00b!
okay.. you ask for instructions.. we give you instructions, then you come back and ask us if they're correct?
Why even bother to look if you're just going to come back here and ask the same stuff again?
Old Oct 24, 2001 | 10:46 AM
Re: THANKS!
you dont have to use the metal brush, but it will help clean the calipers
or you can just use brake parts cleaner (from auto store) by itself and it will work out pretty well
I dont think primer is really necessary; many people put a coat or two of clear coat on at the end to help protect the paint
Old Oct 24, 2001 | 04:43 PM
krazyd's Avatar
YEAH OK!
Old Oct 24, 2001 | 07:56 PM
BIGDOG's Avatar
I would def. use some clear coating.. It helps to protect the paint and it also help when your trying to get all the brake dust off. Thatts the biggie. You will have to clean them like once a week. Atleast I do. And some people say to use the high temperature paint. I dont see where that is really ness. I used regular paint from Advance Atuo that almost matched the color of my car and it seems to be working fine. They have been painted for more than a year now. Hope this helps
BIGDOG
Old Oct 25, 2001 | 07:15 AM
BIGDOG
go drive your car for 30 minutes with lots of braking
get out and go rub your hands on the calipers and rotors for a little while and then decide if you think maybe the brakes do get hot after driving
maybe the paint you got is better than others, but I would definitely recommend using high temp stuff so it wont bubble, peel, or melt off
Old Oct 25, 2001 | 08:09 AM
maxmizd27's Avatar
I used the Folia Tec stuff. It's awefully expensive, but you don't need to clear coat it and it has lasted for YEARS and still looks very good. It's epoxy based and is very durable. You don't have to touch it up every couple of years. Can't believe how it still looks after almost 4 years. Worth it in my oppinion.
Old Oct 25, 2001 | 12:58 PM
Bman's Avatar
Hmm, letsee.... {touches brakes} YEEEEEEEEEAAAAAAAAARRRRGGGHHH!!!!!
Old Nov 1, 2001 | 08:43 PM
Nathan's Avatar
krazyd, if your looking for some caliper paint, I'm the guy that is running the group deal on the foliatec caliper paint. If you look under the group deals section you'll find the info. You can email me at: stricklymaximas@hotmail.com if you're interested.
Nathan
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
