Adj to E Brake
Old Oct 24, 2001 | 05:13 PM
BIGDOG's Avatar
Adj to E Brake
Hey can anyone help me out by telling me how to adjust the e brake. I had new brake shoes put on bc they were gettin kinda low and I thought that might be the reason but it still dosent work. Anyone tell me where the adj. to the cable is?
BIGDOG
Old Oct 25, 2001 | 07:20 AM
«§»Craig B«§»'s Avatar
Re: Adj to E Brake
BIGDOG
it should self adjust (at least it does on disc brakes, maybe your drums are different). I just pull mine a few times when i put new pads in and it will tighten up
first you take out the center console:
pop off the shifter surround trim piece (just use something to pry it up from the bottom)
2 screws in back that you have to move seats all the way forward to see, 2 in the front on each side and 2 in the middle under a little popoff panel under the ebrake
unbuckle the seat belts and remove the "pawl" that goes between the belts and the console and prevents the seatbelts from retracting too far (they just pop out if you push in one side)
take out center console (up and a little forward to clear the ebrake handle)
there is a small nut at the bottom of the ebrake to adjust it
Old Oct 25, 2001 | 03:05 PM
BIGDOG's Avatar
Re: Re: Adj to E Brake
Thats for all the help. THat worked great. Now maybe my car will pass Inspection.... If they dont Check all the other Modifications
Bigdog
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
