CV Boots
Old Oct 26, 2001 | 04:15 PM
ObsidianIce69's Avatar
CV Boots
Does anyone have any advice for changing CV boots? Is it better to do it yourself or to have a dealer do it? A shop said they'll replace the whole axle for $125. Would it be better for me to just do the boot or replace? And how about handling the replacement myself? Thanks
Old Oct 26, 2001 | 04:18 PM
Jon91SE's Avatar
Pusssseeeehhhh
Re: CV Boots
unless the axle is damaged there is no reason to replace it , boots are no big deal just replace it when you can the sooner the better.....
Old Oct 26, 2001 | 09:36 PM
slacky92's Avatar
Re: CV Boots
[ If the joint is making noice ie loud clicking when car is turning hard right and or left then it is probably time to change the whole axle. From my experience with other vehicles this is a job where the labor to replace the boot is equal to the labor costs to replace the axle.
Old Oct 26, 2001 | 09:45 PM
MONTARABOB's Avatar
Re: CV Boots
As Slacky sez, as long as yours is not "clicking" (5mph tight turn) joint should still be good. REPLACE boot asap. $125. rebuilt shafts are c h e e p and dont hold up over the long run. Get a quality boot. OE kit runs about $40.
Old Oct 27, 2001 | 12:12 AM
blackandwhite's Avatar
To them I'm like an idol
Cvaxles.com
Check out:
Constant Velocity of Ocala
They have an internet special of $55 per side.
Old Oct 28, 2001 | 01:48 PM
Thanx
Well there's no Clicking noise so i'll be replacing the boot then. Thanks Fellas!
Old Oct 29, 2001 | 01:27 PM
Re: Cvaxles.com
Originally posted by blackandwhite
Check out:
Hey,..are you saying the whole axle for $55?
Old Oct 29, 2001 | 02:02 PM
Re: Re: Cvaxles.com
$55 per side plus a $50 core charge per side that they return to you when you send your core back.
So $110 for both + $100 in core charge, unless you send the core first.
The $125 they quote is probably labor only, or just labor plus the boots. But labor to do the boots is probably the same as replacing the whole thing.
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
followthadollar
Sep 17, 2015 06:31 PM
Bonka
Sep 14, 2015 11:18 PM
